![]() Drives: 2014 Yaris Join Date: Sep 2015
Adding 12volt cigarette lighter to rear
So I'm wanting to add a 12volt cigarette outlet to the trunk of my Yaris, to power a next-to-be-installed rear facing dashcam.
(I figured adding a 12volt cigarette outlet in the hatchback trunk, then using the dashcam's included 12v cigarette adapter, would be easier than hardwiring) To install, I think I would just need to get a female socket like this one: https://www.ebay.com/itm/131333723351?rmvSB=true Then I can run the positive/negative wires (or ground the latter) to the front, and hook it up to the fuse box using an add-a-circuit? I probably only need the outlet to have power when the car is on, so I would find & tap into an switched fuse outlet. That's my understanding on how I would go about doing so, but I'd appreciate confirmation if this is correct and any suggestions/advice! Thank you. Oh, and I drive a 2014 Yaris hatch, in case that makes any difference. |
| Does the Yaris Hatchback 2007-2008 have Cigarette Lighter Port? | TwisteD | General Yaris / Vitz Discussion | 10 | 08-13-2015 05:15 AM |
| Tried to replace cigarette lighter fuse, think prongs are stuck inside. Help please? | wiirenet | DIY / Maintenance / Service | 10 | 01-31-2013 08:31 PM |
| Someone have any idea of adding rear foglights? | TitaniumBarbell | Cosmetic Modifications (Exterior/Interior) | 3 | 06-02-2009 12:20 AM |
| Adding 2 Rear Speaker to Yaris CE edition. | alexzz44 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-02-2008 01:04 AM |
