Old 05-17-2017, 07:02 PM   #1
Jamie101
Drives: Yaris 2002 1.0
Japanese engine into French Yaris 1.0 2002
Hi everyone.
As the title says im halfway through an engine swap and noticed the cam sensor plug is different - i read on the net that said all i have to do is tap the pins out a little on the cam to accept the new cam sensor fit the knock sensor and then change the crank rota wheel behind the cam chain cover for the crankshaft sensor.
I have stripped it down and they are slightly different but if i change them would it effect the cars ignition timing at all as when the replacement one os fitted ontothe nose of the crank keyway the bit of the wheel that has a flat is in a different position to the original ???
Bit confused here? Any help greatly appriciated.
Jamie101 is offline   Reply With Quote
03 Yaris 1.0 VVti Engine Swap, URGENT help needed. philwept_33 DIY / Maintenance / Service 1 05-15-2009 12:15 PM
