Old 06-09-2018, 12:02 AM   #1
ryanquad
Drives: 05 echo sedan turbo
weight reduction
wondering how light you can get these cars
please share how much you've stripped and the weight of your car now
ryanquad is offline   Reply With Quote
Old 06-09-2018, 08:59 AM   #2
tmontague
tmontague's Avatar
Tom from Armstrong Racing will chime in I'm sure but last I checked he was down to 2100lbs with a stripped interior, wire harnesses that are not needed and replaced some of his glass w/ lexan
Old 06-09-2018, 10:44 AM   #3
DarkShadowFox
carbon roof. aftermarket rotors. removing the back seat. lighter wheels. removing the passenger seat. aftermarket suspension. lexan windows. carbon fiber hood. aftermarket brake calipers. removing the AC if you don't need it.
Old 06-09-2018, 10:03 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
My racecar is high 1800s fully stripped.
2014 BSpec Divisional Champion
Old 06-13-2018, 09:28 PM   #5
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
I'm at 1951 now with a SEDAN, but I could go lower for sure. I sill have all of the door beams and all hinges/latches, and sound deadening. I have the glass rear window still too.
ArmstrongRacing is offline   Reply With Quote
Old 06-17-2018, 02:22 PM   #6
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
I'm at 2044lbs with a Full interior minus the back seats and about 1/3 of a tank. I can easily get it to 1999 and keep most of the comfortable stuff in..........amazing!
Ronnie V is offline   Reply With Quote
Old 06-17-2018, 06:04 PM   #7
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
A lot of people could also stand to lose at least 30-60 lbs.
Kalispel is offline   Reply With Quote
Old 06-17-2018, 10:08 PM   #8
2080lb showroom stock for an echo hatch ;)
Old 06-18-2018, 07:12 AM   #9
Ronnie V
That must be a dry weight?? and the 5 door has to weigh a bit more than the 3dr no?
Weight reduction and F/R Balance eTiMaGo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 04-24-2017 12:00 PM
Weight Reductions scape General Yaris / Vitz Discussion 34 06-08-2009 02:31 PM
Weight Reduction Stage 4 - DIY SeaYa General Yaris / Vitz Discussion 9 02-24-2009 09:26 PM
Weight Reduction Stage II Pics Yaris T-Sport Performance Modifications 21 10-01-2007 01:57 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
