Old 08-25-2006, 11:21 PM   #1
imknotright
Drives: 07 Yaris sdn
Add remote to factory keyless.
My 07 Yaris Sedan with factory keyless only came with one remote key (Which seems to be normal). I wasn't going to pay the $200 plus dollars for one from the dealer. I found one on ebay for under $100 (MAKE SURE THE FCC ID INSIDE MATCHES YOUR CURRENT REMOTE) . I got it cut & then programed it myself. For factory keyless remotes I used instructions for Toyota TSB EL004-01.
1- Driveres door open & unlocked. Key out of ignition
2- Insert & remove key 2 times within 5 seconds
3- Close & open drivers door twice within 40 seconds
4- Insert key into ignition & remove
5- Close & open drivers door twice within 40 seconds
6- Insert key into ignition
7- Close the door
8- Turn ignition switch from "LOCK" to "ON" & back to "LOCK"
- ONCE for ADD mode
- TWICE for REWRITE mode
9- Remove the key from ignition
10- To confirm your mode selection, the power locks will now cycle "lock" to "unlock" a
number of times corresponding to your key cycles in step 8
11- Within 40 seconds of confirmation
- Press both transmitter Lock & Ulock buttons simultaneously
- Within 3 seconds press transmitter Lock button for more than 1 second
- If successful, the power locks will cycle once (twice indicates transmitter problems)
- Repeat step 11 for additional remotes
12- Open door to exit programing
imknotright is offline   Reply With Quote
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
FS Various OEM keyless Remote riceboy Items for Sale by private party 0 04-14-2006 02:42 PM
