Old 04-16-2018, 03:34 PM   #1
xxcanuckxx
Drives: 2015 SE HB
2007 3 door vs. 2015 5 door?
Is anyone still exchanging ideas here?
I am going to retire my 2007 LB soon, and am trying to decide if I should buy a new for me 2015.
What do you guys think? Is the 2015 still compatible with 2007 parts?
It feels like the community isn't as active anymore.
Do the newer Yaris accept all the tinkering that the old ones did?
I guess what I am asking, is, can I expect all the same enjoyment out of the 2015, or has everything changed?
Side note to Canadian coilovers owners, how are you finding them after 1 or 2 winters? I have heard about nightmares of them rusting up and no longer being adjustable...
xxcanuckxx is offline   Reply With Quote
Old 04-16-2018, 04:05 PM   #2
Other than cosmetics, everything is still the same.
Old 04-16-2018, 04:58 PM   #3
any power and suspension parts should transfer to the new one.
coilovers will definitely seize up after a winter of driving on them. but after you set them, you shouldnt really have to move them again.
i used to swap coilovers in/out in spring/fall respectively when i had my 07 yaris in kitchener, on
Old 04-16-2018, 05:09 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
I think coilovers should be fine if you rust proof them. Ie, think layer of bearing grease.
Sent from my ONE A2005 using Tapatalk
Old 04-16-2018, 10:46 PM   #5
Then grit gets in the threads...
Old 04-17-2018, 08:30 AM   #6
bentjazz
Drives: 2009 Yaris--3dr MT
When/if I give my Yaris to my nephew in 3 years or so, I'm not going to hesitate
in buying another Yaris (that is, if the hb is still available).
bentjazz is offline   Reply With Quote
Old 04-17-2018, 01:22 PM   #7
Runethecursed
Drives: 2009 Yaris S
copper based lubricant
either way you gotta deal with rust, or gritty lube..
id deal with gritty lube anyday
Runethecursed is offline   Reply With Quote
Removing Door Panel for a 2007 Toyota Yaris? helloopio DIY / Maintenance / Service 2 04-11-2014 07:22 PM
The wind blows the Yaris door Jabberwocky General Yaris / Vitz Discussion 49 04-02-2014 10:40 PM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
