Old 05-26-2018, 09:47 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Paint Booth for Full Respray - Video of booth added...
I've started the booth in my garage. Hoping to be done by mid-week. I bought 2 20" box fans and 6 furnace filters. Next is to procure lighting. I'm hoping to pick up used fluorescent fixtures and have a lead on a few 48" ones.
I built the frame so that it could be easily disassembled and stored. Each wall is screwed and glued with construction adhesive and each wall is detachable. I used strapping for cost savings. It's actually very solid. Once done, the entire thing will be covered in heavy poly sheeting and sealed with Tuck Tape.
Approximate dimensions of the booth are 19'(L) x 12'(W) x 7'(H). There is decent room all around but I wouldn't want to try painting a car much bigger in there.
I am leaning toward a negative pressure set up. I think that with the two fans and 6 filters, I should be able to evacuate the fumes/overspray quite quickly. I am going to rig up cups for the back of the fan motors to eliminate airborne material from going through the motor. However, I will probably experiment with a positive pressure system before making a final decision.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
