foreign oil = dependence
Drives: 3 door Join Date: Mar 2007
Megan or Tein suspension
Question? I'm trying to find the best suspesion to lower my Yaris, the "Tein Basic" looks pretty good, but offers no adjustment to the shocks (dampening, I guess you would call it) only ride height, I've heard a lot of good things about it though. Megan Racing has a coilover kit too, it's called the "Megan Coilover Damper Kit " and you can adjust the ride height and shock dampening. I haven't heard of either of these companies before, until I found this site (Yaris World), and I've read no reviews of the Megan suspension. If anybody has knowledge of both systems or even is using one or the other and can offer an opinion I would greatly appreciate it.
Many thanks, Elmer |
Insert sarcasm here.
The one thing to keep in mind is the ride quality. I was researching the two and noticed that the Megan coilovers have a much higher spring rate then the Teins did. This could attribute the a much more harsh ride, but it would be good if you planned on racing it.
Thats really all I know. Tein is a lot more well known, and probably a more comfortable daily driver suspension. Good luck with your decision let us know what you decide. I'd be VERY interested to hear some reviews on the Megans. |
![]() ![]() Drives: Toyota Yaris T SPORT Join Date: Feb 2006
Ive got a good ride quality on my Tein Damper Coilover kit, much more comfortable than what I though it would be... Go get it!
![]() ![]() ![]() Drives: '00 Toyota Celica GTS Turbo Join Date: Aug 2006
I'd go tein all the way!
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
Well, I have decided on Megan but it will be another month or two before I get them installed.
SPONSORED BY
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Do you have to contact the company direct to get info? I have Megan springs (NOT coilovers) and haven't found any info on spring rates. It's much firmer than a stock AW11 MR2 but softer than my 80 RX7 (but this RX7 is firmer than others I've driven..don't know what's been modified), but exactly how I like them...street/daily driver and no racing. Let me know if there are any sites listing comparisons of rates...I'm interested.
____________ Old School Cobble Jockey
#7 | |
Lonesome Cowboy
Megan Coilovers Spring Rates: 6kg Front and 5kg Rear and Tein F:4k R:3.1k matter of fact here are all the specifics Megan Coilovers Features: Spring Rates: 6kg Front and 5kg Rear 32 Levels of Adjustable Damper Rubber Dust Covers. Adjustable Ride Height Aggressive Spring Rates Single-Cyliner Design Aluminum Brackets 32 Levels of Adjustment: 1-8: Suggested for track use. 9-16: Suggested for mountain/aggressive use. 17-32: Suggested for common street use. All coilover damper kits come with 1 year manufacture-defect warranty. All Hardware is Included SELLING PRICE : $895.00 per set. Tein Specifics Spring Rate: Front: 4 kg/mm / 224 lbs/in Rear: 3.1 kg/mm / 174 lbs/in Ride Height Front: -1.9 in Rear: -1.9 in Ride Height Adjustment Front: -1.3 ~ -2.8 lbs/in Rear: -1.2 ~ -3.0 lbs/in TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price. The Basic damper MSRP starts at $750.00, which includes 4 springs and 4 shocks. Compared to the "sleeve type" coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force. High performance and cost effective. Ride Height adjustable. New paint coating for rust prevention. Exclusive design for USA vehicle specifications. (only available for the U.S.A Market). Available for overhaul. Contents of damper kit Height Adjustable shock absorber x4 Main spring x4 Lower spring seat x4 Seat lock x4 Thrust washer x4 Bump rubber x4 Dust cover x4 just for fun the Tanabe DF210 are Spring Rates F/R 3.0 / 2.2
SPONSORED BY
Last edited by brickhardmeat; 05-16-2007 at 08:50 PM. Reason: Tein are only 910. we are not talking much price difference at all here. |
Do the coilover rates have any similarity to just the lowering coil rates? (say for the Megan springs?)
Lonesome Cowboy
Well, judging by the Tanabe spring rates I listed yes I guess so but the Megan Racing Springs say for the Yaris, (Note: Spring rates and drop amount vary by different vehicle application and chassis load.)
They do however list spring rates for other applications. Leads me to believe the spring rate for Yaris is yet to be determined. Various spring rates for megan racing springs I have found are anywhere from 200 to 350.
SPONSORED BY
Lonesome Cowboy
off subject somewhat for this thread but how did your springs settle? did you end up with 1.5 drop a little more less? have you measured?
SPONSORED BY
Measured after a couple weeks and its probably more like a 1.375 drop both front and rear. Carried a load of 4 truck tires w/rims to a friends today (parting out Big Bertha the van, who needs a truck when you have a LB)....actually think I would have to try hard to ever bottom out. Firm, the way I like it.
don't feel like reading through the replies right now, but from my experiences with these two companies, i'd go with Tein. i had lowering springs from Megan on my GTI when i had it, and i have Tein springs on my Yaris. the Megan springs promised a two inch drop, but i only got, at most, a 3/4 inch drop. the S.Tech's did what they said they would. oh, and the Megan springs were not at all stiffer than the OEM springs.
#13 | |
Lonesome Cowboy
but we are talking about adjustable coilovers for the most part here, that is how the thread originated
SPONSORED BY
#14 |
From what I see the megans are a better choice. Stiffer, threaded strut mount (dosnt limit travel when lowering) and they seem to be of alright quality. The shocks are made by Bor Chuann ( http://www.bcec.com.tw/ ) which are rumored to make Apexi shocks but I don't know for sure. Also the springs look to have a very similar finish and text to the Cuscos. Once again I don't know if that means anything. The thing that really needs some improvement is the instructions, pretty vague and written in poor english.
I be putting a set on Friday and Ill give a review then. Please bear with me as my composition skills are not the best. The only thing that bums me out on them is that all of Megans other applications come a lot more cool stuff for the same price. (pillow balls) |
#15 |
#16 |
#17 |
#18 |
Tein Basic's would be a better choice for a daily driver...
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 05:08 PM |
| TEIN - Basic Coilovers *Now Available* | EnduroMTS | Sponsors Classifieds Area | 4 | 10-13-2006 02:43 PM |
| TEIN Basic coilovers | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 06-26-2006 01:57 AM |
