Old 11-19-2018, 03:41 AM   #1
komichal
Yaris cabin "breath out" hole
Hi folks,
the previous car I drove (Mitsubishi Galant) as well as the other cars I met had a well hidden hole with rubber cap somewhere in the interior. The only purpose of the hole was to let the pressurized air flow away when closing door as in certain moment the door seal was already sealed but the door still moved towards a full close which means a pressure built up inside the cabin for short time. That hole helped to mitigate this.
That means that in my previous car I did not have to extra-SLAM the door when I was closing the last one.
Does Yaris have something like that? Probably not (or if yes then it is clogged). Because when I am closing the door I really have to extra-SLAM the last one, especially when cabin external air blower is engaged. It is not a problem of the door hardware because when I keep any window a bit opened then the problem disappears.
It is nothing major, I can live with that. Maybe this thing is only installed in some expensive limousines and not in wheeled candies like Yaris.
Old 11-19-2018, 07:06 AM   #2
ex-x-fire
Seems like it would hurt your eardrums, I don't have that problem on my Yaris.
Old 11-19-2018, 09:11 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
There are one way valve holes at the back of the car. You would see them on each side when the bumper cover is off.
Sent from my CLT-L04 using Tapatalk
Old 11-19-2018, 01:03 PM   #4
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
http://www.japan-parts.eu/toyota/eu/...ide-ventilator
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 11-20-2018, 03:05 PM   #5
komichal
Thanks folks, will check them out!
Old 11-20-2018, 04:27 PM   #6
DarkShadowFox
mine must be broken or something because my cabin fogs up. any solutions?
Old 11-21-2018, 09:04 AM   #7
nortonfb
Drives: 2007
You may have a water leak, not uncommon.
Number of threads on here about it.
Check your carpeting for moisture and the spare tire well.
nortonfb is offline   Reply With Quote
Old 11-21-2018, 09:14 AM   #8
IllusionX
Old 11-28-2018, 12:17 AM   #9
2008RedHatch
2008RedHatch's Avatar
Drives: 2018 Yaris LE liftback, 2020
Check A/C drain. Also, use the "outside air" selection on fan in cooler weather, instead of "recirculate", which is meant for cooling a hot car in summer.
2008RedHatch is offline   Reply With Quote
Old 11-28-2018, 07:44 AM   #10
Cabin pressure is relieved via the air extractors located behind the rear bumper cover. Yours may be stuck closed some how (maybe a ton of spider webs or other debris are preventing the rubber flaps from opening when the doors are shut).
Old 11-28-2018, 07:46 AM   #11
Clean the inside of your windows. I noticed that if I'm lazy and haven't wiped down the inside of my windows, they fog up easier when there is an imbalance of temperature between the cabin and the ambient temp.
2015 Yaris SE (m/t) - Week-One Impressions - The Good, The Bad, & The Ugly. Kalispel Third Gen Yaris General Discussion 53 04-29-2016 10:35 AM
FS: Various Parts from a 2009 Yaris Hatchback Freestylin Items for Sale by private party 17 02-24-2016 09:36 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
