Old 02-11-2019, 11:00 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Touch Your Car Before you Pump Gas
Never thought about this:
https://www.msn.com/en-us/autos/owne...cid=spartanntp
Old 02-11-2019, 11:09 AM   #2
Let's see...
- touches driver door to close it when exiting vehicle at pump.
- touches fuel filler door to remove gas cap.
Both metal. I think I'm good to go without needing to consciously think about it.
Sent from my EML-L09 using Tapatalk
Old 02-11-2019, 11:42 AM   #3
Leegamer
Leegamer's Avatar
Has anyone actually ever started a fire by not doing this? I've heard this since I was a kid.
I'm a hermit named Lee
Old 02-11-2019, 03:14 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Is that a Yaris in the stock photo at the top of the article? lol
On Instagram
On Wheelwell
Old 02-11-2019, 03:19 PM   #5
Leegamer
Leegamer's Avatar
looks like a chevy cruze?
Old 02-11-2019, 05:51 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
200 incidents in 30+ years. I don't think it's a real problem, otherwise it would be mandatory procedure to discharge yourself before putting gas. :)
Sent from my CLT-L04 using Tapatalk
Old 02-11-2019, 08:49 PM   #7
It's been a subconscious habit of mine to touch the key hole (since it isn't painted) before I pump gas. I would also touch those metal poles they have (you know, the ones at the corner of the pump in case you drive into it?). Both Yarii I've had gives my body a lot of static for some reason. I don't have that issue with my FR-S, yet I still touch the key hole. lol.
Also, I think realistically, unless you're running super empty, sparking the fuel would be quite difficult. I think Mythbusters did a test before.
Old 02-12-2019, 10:55 AM   #8
bronsin
bronsin's Avatar
How about filling up gas cans?
Old 02-12-2019, 11:02 AM   #9
IllusionX
That must be done outside the car.
You shouldn't fill the can while it is sitting in the trunk or something.
Old 02-12-2019, 11:08 AM   #10
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Gas cans should be on the ground when filling.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-12-2019, 04:17 PM   #11
dogsridewith
Drives: 2007 2-door hatchback
Static electricity discharge Toyota
I've had synthetic materials seat covers in my three Toyotas. All were zappers and, depending on conditions, could make sparks I wish I had in some small engines. It is shocking to experience one of these through the hand. They remind why my usual habit, sometimes neglected, is to get out of the car and first touch the door with my arm...on the outside, somewhere between shoulder and elbow IIRC.
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) CTScott DIY / Maintenance / Service 1 08-21-2013 03:57 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
