Old 01-01-2019, 06:46 PM   #1
grilled cheeseus
Drives: 2007 3 door 5MT
Adding bold speedometer markings??
The speedometer on my '07 hatchback is hard to read at a quick glance, especially when you're approximately halfway between the major ticks at 10 MPH intervals. Am I going 53 or 57? Iono, let me squint at it for longer than I should while driving. The minor ticks (1 MPH intervals) blur together and are basically useless.
So, usually I just look at the digital speedometer on my Scangauge, but after disconnecting it to help a friend diagnose his CEL, I drove home with only the stock gauge and was reminded how crappy it is.
What if we add bold ticks at 5 MPH intervals? It's trivially easy to remove the gauge cluster and its clear plastic lens. I've done it in literally 2 minutes with a philips screwdriver. Then you can do whatever you want on the panel itself.
Maybe with little white stickers or a "correction pen", or maybe etch away the plastic so they glow at night?
grilled cheeseus is offline   Reply With Quote
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 12:42 PM
