Old 11-13-2018, 05:57 PM   #1
HaavardPYA
Drives: 2001 Yaris Verso 1,3
2NZ FE poor acceleration
Hi. I just bought an 2001 Yaris Verso 1,3 vvti. The acceleration is really bad and when i change gears on 50-100% throttle it jerks just when i release the clutch after shifting.
It has a bad exhaust, so can this be a problem coming from the two o2 sensors reading wrong values causing rich or lean fuel mixture? The yellow engine light also comes on after driving for about 20-30 minutes after resetting the ECU.
I have not had a chance to getting the car up on jack stands locating the leakage yet, but I will do it this weekend. Also going to clean the IAC, throttle body and MAF at the same time. The coolant level is at max in the expansion tank, but sometimes when cold, the coolant lamp comes on. OBD tool is allready ordered.
Something else you would recomend me to do at the same time?
best regards
HaavardPYA is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
2013 yaris 2nz yaser DIY / Maintenance / Service 0 12-14-2015 07:47 AM
2nz pistons in 1nz salmanghiyas Performance Modifications 1 11-15-2014 01:30 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Turbo for 2NZ.... Centurion2200 Forced Induction Forum 9 08-25-2007 06:14 AM
