Old 02-26-2019, 10:23 AM   #1
toad
toad's Avatar
Drives: street-legal go-kart
manual tranny drain/fill on echo?
I've read the DIY for the Yaris manual transmission change, but was curious if everything is the same with the Echo? I know the air box is in a different location, but will the drain/fill plugs be in the same areas and use the same size(24mm) socket? My 5-speed echo is having trouble shifting into gears(3rd especially) and I bought it used so I'm not sure if the gear oil has ever been changed
It's got a little over 140k miles on it and I've got some Redline 75w-90 gl4(2 quarts) coming today. I took a look under it last night, but it was getting dark. I'm thinking I may need to remove the battery to get at the fill plug(if it's where I think it might be), but thought I would ask first before I start removing things thanks in advance!
toad is offline   Reply With Quote
no manual tranny for 2019 sedan? Mike MR2 General Yaris / Vitz Discussion 5 03-17-2019 03:09 PM
Manual tranny Yaris bentjazz General Yaris / Vitz Discussion 26 12-11-2018 02:09 PM
Where to buy service & repair manual? (and Parts manual?) 2010 Yaris Sedan TYaris2010 DIY / Maintenance / Service 1 07-08-2018 09:38 AM
Manual Yaris performance info? SimmZ General Yaris / Vitz Discussion 22 10-27-2009 09:27 AM
