Old 03-08-2019, 08:16 PM   #1
krolos
Drives: 2008 yaris sedan
ac compressor bypass.
Well it seems the ac compressor is shut, I did the bypass with
the shorter w/o ac belt and installed it, went for a drive and everything
is fine. What about the wires connected to the compressor should
I disconnect those to?
krolos is offline   Reply With Quote
Old 03-08-2019, 08:54 PM   #2
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I would imagine they only control the clutch on the compressor pulley... but I'm no pro.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 03-08-2019, 09:45 PM   #3
tmontague
tmontague's Avatar
Yes they only control the a/c to engage or not. You can likely leave them in tact without issue
