![]() Drives: Yaris 2, 1.3 VVTI, 2008 France Join Date: Feb 2019
1st gear shaking and very stiff clutch
Hi,
I've a 2008 Yaris 1.3 VVTI (Made in France), 120000km, with the problem of shaking (judders) in first gear and a very stiff clutch. I've read many things about this problem but I still wonder what to do... - Replace Clutch ? Which one to choose? - Replace concentric slave cylinder ? - Replace flywheel ? Or only pressure plate ? - Add modified gear selector parts ? - Replace hydraulic clutch fluid and bleed master cylinder and slave cylinder ? - Replace gear box oil with Synthetic GL4 75w ? Did anyone already get rid off this problem ? And what can I do to resolve it ? Greetings from France. Last edited by Olea; 02-13-2019 at 05:40 AM. |
I've also observed that the car isn't jerking / shaking on first gear with A/C on.
What does it mean ? Envoyé de mon LG-H870 en utilisant Tapatalk |
#3 | |
I had a friend tell me that, his 06 Yaris (no AC) always studers when taking off, so I drove it and it didn't happen. As for the grinding feeling, it happens to me too, when the engine is still cold. The issue is the idle is different when cold vs fully warmed up, and you still clutch the same. So the clutch slips, and tries to grip and get this grinding sensation. It is actually an issue, I get that with a bad pressure plate on my previous "Yaris" (04-05 echo). My 07 does it a little, maybe that's why the clutch is pretty worn at 180k km. Envoyé de mon téléphone ![]() Sent from my CLT-L04 using Tapatalk |
Ok. Let me know your driving method, then I will try it and see if it doesn't shake anymore
![]() ![]() Regards. Envoyé de mon LG-H870 en utilisant Tapatalk |
There is no miracle, you have to learn. The Drive By wire throttle doesn't help at all.
The Yaris also have a pretty stiff clutch pedal compared to say, a 2015 corolla, or a 2010+ Honda Fit. Sent from my CLT-L04 using Tapatalk |
#6 | |
CONSTANTLY press right pedal to obtain about 1500rpm-2000rpm while let out left pedal very SLOWLY That's all ![]() Envoyé de mon LG-H870 en utilisant Tapatalk |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
Personally, I feel releasing the clutch from 2000 rpm in first gear is slipping it a bit too much. I also get a shuttering and vibrating dash when taking off in first but I take off around 800-1100rpm. I've learned to ignore the noise and vibration. 306,000km on the original clutch and it still grabs great. I'm not the greatest standard driver by any means but ive never killed a clutch. Must be doing something right.
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
When I start the car in the morning, it idles between 1500-2000rpm anyways.
Hopefully not for too long lol. Mine sits at 1100 or so when cold, 600 when warm.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
shutter clutch
mine does that also but notice that when I push back in on the clutch pedal it stops and then release again on the clutch it won't do it again. Is that mean the clutch or pressure plate is going bad???? anybody?
