![]() Drives: 2008 Toyota Yaris Join Date: Mar 2019
Replacing rear shocks
I have a 2008 yaris sedan. I know that the hatchback has the location for screw for the rear shocks in the trunk, but where do I access the top screw on the sedan.
Thanks, |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
rear shocks
I replaced mine last year, lift up on a plastic cover in the trunk right above the tire. very easy to replace those shocks.
#3 | |
Sent from my EML-L09 using Tapatalk
The access is actually from the cabin not the trunk. Flip down rear seats and you will see plastic cowlings beside each seat that goes around the wheel arch.
Remove those and the shock mount is behind it. For future you can always cut a hole in the plastic as the seats cover it anyways
Here is a picture of the top of the shock with everything removed
Well that pic might just scare the crap out of the OP. He's new and prob doesn't know why your car looks like that.
Lol, it was meant to show where the location is so that you know what is in the way that you need to remove. Not everything in that image needs to be removed!
![]() ![]() Drives: 2008 Yaris 3DR Hatch MT Join Date: Dec 2018
Thanks for the information, i will be doing it this weekend!
| Stock OEM front struts, aftermarket rear shocks? | rexseesyou | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-25-2014 12:16 PM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
