Old 05-22-2009, 03:12 AM   #1
AlainMikli
AlainMikli's Avatar
Finally...Bride Racing Seat Installed
Thanks Malaya1121 for all the helps
Recaro Slider & Wedge Engineering Custom Bracket..
Will take some more pic tomorrow
Old 05-22-2009, 03:14 AM   #2
AlainMikli
AlainMikli's Avatar
Finally
I even bought these seats before I get the Yaris
To do: Supercharger…
Old 05-22-2009, 03:16 AM   #3
AlainMikli
AlainMikli's Avatar
However, the passenger side air bag & seat belt light keep blinking.....
My solution is.....
Anyone Can Help
Old 05-22-2009, 03:20 AM   #4
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Those seats look awesome! Any problem with fitment???
fuji is offline   Reply With Quote
Old 05-22-2009, 03:32 AM   #5
fuji
fuji's Avatar
I wonder how to get past the passenger air bag and seat belt light. There must be a way of hooking up the sensors to work with the Bride seats.
Old 05-22-2009, 04:06 AM   #6
AlainMikli
AlainMikli's Avatar
Perfect
These nothing wrong with the Driver Side, however the Passenger Side have a big problem with it, because there is a weight sensor of the passenger seat and there're none of the Bride seat...
I really want to know how to by pass the Weight Sensor & Passenger Side Air Bag
Originally Posted by Taiyaki View Post
Oh man I love your solution! thats was great. I laughed hard.
your seats are sick
That's what I can do right now
Old 05-22-2009, 03:52 AM   #7
Taiyaki
アキバ製
Taiyaki's Avatar
your seats are sick
Old 05-22-2009, 04:35 AM   #8
808_Yaris
Where is Oahu?
808_Yaris's Avatar
Drives: 5-door meteorite metallic
niceee seats! install the controller let me know if you have any questions
808_Yaris is offline   Reply With Quote
Old 05-22-2009, 12:55 PM   #9
AlainMikli
AlainMikli's Avatar
I dont have time this week, I'm kinda busy
may be Next week~
Originally Posted by scape View Post
from what I remember, the passenger seat has a weight sensor in it, anything over that limit and the air bag light and seatbelt light goes off. removing the seat all together means you removed that sensor in the seat's bottom, and it probably needs to relay the signal. was there any connections you had to unplug while removing the original seat?
There's 4 sensor under the original pass. seat, however, Malaya1121 told me he tried to unplug all of them from the stock seat and plug back in, but still uesless
Old 05-23-2009, 12:14 AM   #10
may be Next week~
If you move the sensors over, you also have to move the Occupant Classification ECU, which is located under the front of the passenger seat. There is a calibration that a Toyota Tech can do with the Techstream tool to zero-out the system.
Looking at the service manual and EWDs I believe you can bypass the sensors by supplying 0.2 VDC to the SIG1, 2, 3 ,and 4 terminals (on the 4 connectors that plug into the 4 Occupant Classification Sensors).
Connector U1-U4:
Pin 1 - SVC
Pin 2 - SIG
Pin 3 - SGD
The normal operating range for SIG is 0.2 to 4.7 VDC. If you connect up the 4 sets of resistors, theoretically the light should stop flashing (and I believe that this will be the Passenger Airbag Off mode). If the passenger airbag is on with the resistors in place, flip the 10K and 470 ohm resistors so that the 470 is connected from SVC to SIG and the 10K is connected from SIG to SGD. The service manual doesn't indicate if 0.2 V is empty seat reading or if 4.7 V is.
Old 05-22-2009, 06:13 AM   #11
Awesome seats!
Old 05-22-2009, 08:55 AM   #12
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
Old 05-22-2009, 09:15 AM   #13
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Does the Yaris have side-impact airbags that come out of the seat?
bearda is offline   Reply With Quote
Old 05-22-2009, 10:04 AM   #14
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
No. b and a-pillar only.
Seats look great. Good luck with the weight sensor.
Old 05-22-2009, 09:24 AM   #15
NICE -- what model BRIDES are those?
Old 05-22-2009, 09:55 AM   #16
MPC Motorsports
Drives: 2008 Yaris S Sedan
On the bottom of the seat they say "ERGO II".
MPC Motorsports is offline   Reply With Quote
Old 05-22-2009, 09:55 AM   #17
MPC Motorsports
Where did you get them and how much did they cost???
Old 05-22-2009, 12:50 PM   #18
AlainMikli
AlainMikli's Avatar
I bought it back from Hong Kong with a Super Awesome deal.....almost half price of the RSVP in US
driver Side : Eugo II
Passenger : Xax II (Easy for passenger to get off)
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
