Old 04-20-2020, 11:54 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Rotor Painting Experiment
Since I had a bit of 2K epoxy primer let from my wheel restoration, I thought I do a little rotor painting experiment. I've had a set of rotors for the Yaris sitting on the shelf forever. These cars never seem to need new rotors.
Anyway, I degreased them really well and then shot them with a couple coats of the primer. This epoxy is supposed to hold to metal like nobody's business. I then topped it with 3 coats of VHT Flameproof ceramic paint.
The reason I call it an 'experiment' is that I really have no idea how much heat epoxy can take. I know of the G2 epoxy kit for calipers but they don't get nearly as hot as the rotors themselves. I know that the VHT paint can handle the extreme heat, but what it can't do is hang on to the rotor for very long. I does not adhere very well.
I'll be surprised if this paint job lasts much longer than the summer, but maybe I'll be surprised. I'll remove the over spray from the contact surface with a razor blade before installing. I'm about to pull the trigger on a set of performance brake pads. I'm leaning toward the Hawk pads, but they're so dang expensive here in Canuk land. I can get the Powerstop z23 pads for a fair bit less.
On to the pics:
Epoxy Primer
VHT Paint
Old 04-21-2020, 07:55 AM   #2
nortonfb
Drives: 2007
My concern is: What happens to the brakes as the paint is worn/burned?
I'm sure it would degrade brake performance but how & how much.
I'm interested to learn more.
nortonfb is offline   Reply With Quote
Old 04-21-2020, 01:49 PM   #3
What? The hats do not come into contact with the pads. OP said he is sanding off the overspray that actually got onto the rotor mating surface, so there should not be any issues with braking performance.
Iridium Sparkplugs Experiment bronsin DIY / Maintenance / Service 45 02-03-2016 09:35 AM
tooter's exhaust experiment... tooter Performance Modifications 25 01-10-2014 02:03 AM
Better fuel economy experiment at MPG-O-MATIC ... Hershey Fuel Economy Forum 3 04-26-2013 04:01 AM
Shift Without Clutch Experiment bronsin Off-topic / Other Cars / Everything else Discussions 26 12-26-2012 11:41 AM
jpmck03's Painted Emblem Experiment jpmck03 DIY / Maintenance / Service 25 05-27-2012 11:31 PM
