![]() ![]() Drives: Yaris 2008 Sedan Join Date: Nov 2010
Changed my control arms 2008 sedan
Just wanted to make a quick post. I changed both my control arms the other day, everything went smoothly, except for having to run over to O'Reillys for a ball joint separator, didn't have it, then Harbor freight to buy one for $20ish. Conveniently HF was on my way back to the house. Popped the joints just fine and figured smooth sailing now, then one of bolts required me to lift the transmission a bit to pull out, easy enough. The engine side decided not to cooperate, so I had to pull the engine side mount in order to lift the engine out of the way.
Everything considers, oversights, it went much better than I expected. I'd already done all my motor mounts before, so pulling the engine mount wasn't much trouble. Probably took me about 3? hrs overall, including driving. Could probably redo it in less than an hour now. Parts used: MEVOTECH CMS86139 and CMS86138. |
#2 | |
![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
One of the previous owners must have offroaded this car. Most of the suspension was crap, of course being my first time buying used, I didn't think to check the suspension, heh.
The ball joints were loosey goosey, and the rubber in the bushings were really cracked up. I had already replaced the stabilizers previously, and the owner before me did the struts and shocks. I think I'll do the rear arm bushings next. When I took it in for an alignment the tech mentioned they would probably need replacing at some point, but were fine for now. I had already been contemplating switching them myself as they dont seem to be that cheap. I watched a few videos, and seems I should just need the spring tool, and the extractor and press tools, I'll make sure to get them from O'Reilly's before starting that job. Also the bottom plate which connects to the control arms needs to be loosened and shifted over to correct the front alignment, but also will be fine for now. Both tires are slightly slanted to one side, car minimally pulls right. |
#4 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
#5 | |
Thanks for the run down! I think I hear that same clunk as well. In my first yaris my back tires were constantly wearing unevenly. It wasn't until I took it into a meineke for alignment that they told me it needed shims installed. Something to consider. All the bastards prior to this (about 5 alignments) never bothered to let me know. |
Was there something wrong with the control arms on the car? Mine are pretty rusty and the bushes are a bit perished but they still seem to have some life in them.
Anyone doing front suspension work on a Yaris definitely needs a ball joint separator. I didn't have one when i did my clutch. I beat on them for ages and they wouldn't shift so i had to take the two bolts that fasten the strut to the knuckle out in order to get the axles out.
| Control Arms | xnamerxx | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 04-11-2013 12:09 AM |
| New 2008 Sedan need some tips please | CaseyA | New YARIS Purchase Forum | 10 | 11-08-2011 05:48 PM |
| 2008 Manual Cruise Control | Vinson1213 | DIY / Maintenance / Service | 1 | 09-07-2011 04:06 PM |
| DIY front control arms | special_k_828 | DIY / Maintenance / Service | 2 | 04-19-2011 11:31 PM |
