Old 06-14-2019, 01:45 PM   #1
tmontague
tmontague's Avatar
MWR AEM EMS 4 P&P ECU
Just a heads up to those with the 2zr. I emailed MWR a few weeks ago inquiring what their recommendations would be for a standalone with the 2zr seeing as it is dual vvti and drive by wire. As usual I received a very brief email back that let me know that they should have something out by early next year.
Keep in mind that I also heard something similar years ago regarding a long tube header and nothing every came to fruition. That said, I have noticed lately a lot of AEM standalone ECU option popping up for the 1zz, 2zz and Lotus 2zr engines which typically are sold as a kit with the EMS 4, boomslang P&P harness and a base tune.
It wouldn't surprise me if they actually were working on a simple P&P standalone option for the 2zr crowd seeing as there is currently nothing available and all they would really have to do is figure out a base tune. A boomslang harness already exists for the 2009+ Corolla for about $750 USD. Although this is much more expensive than wiring in your own universal harness, it would save quite a bit of time and allows you to simply swap back to your stock ecu and harness if ever needed. To me this is well worth the cost is reduction in time but also the ability to conserve the oem ecu and harness. Tuning is new territory for me so I like the ability to swpa back for any reason and keep the car drivable as well as OBD II compliant (if you are in an area that e tests).
Technically you could currently buy a boomslang P&P harness and an EMS 4 separately and have a tuner set it up for you. The problem with that is your car will not run until you have a tuner set it up. A base map save your tuner time (and you money) and allows you to drive it gently to get it tuned. Much more economical this way. It appears that the corolla ecu side of the harness is the same as the xD ecu sid eof the harness and should therefor work the same with xd ECU and harnesses that most of us 2zr swapped yaris have
I'll update this thread if I see or hear anything new, but it looks like the cost would be around $1200 and $1500 USD for the P&P option based on their kits for other engines.
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
VVTi Control with AEM EMS-4 Question(s) KTS Performance Modifications 8 01-01-2015 08:30 PM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
aem EMS-4 standalone ECU maxthehax Forced Induction Forum 19 05-23-2013 11:29 AM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
