Old 03-19-2019, 09:10 AM   #1
ShadowRabbit
Drives: 2008 Sedan
Used Yaris Only Came With One Key...
Hello. I'm new to posting here, and I'm sorry if my search-fu is weak. I'm trying to learn things more or less on my own and I'm a little stuck.
I got a used 2008 Yaris sedan last year, and the dealer said they only had one key. It's not even a Toyota key. It says Axxess+ 35R and has no fob or anything. I'm assuming it's a valet key as well since it doesn't open my trunk (I know, I did a bad job scoping things out before buying).
I've tried to do some research, and so far I'm gathering that I don't have an immobilizer because my ignition has no black ring and is all metal?
My first question is, will I be able to have a key with the fob buttons at all?
Second, am I pretty screwed when it comes to getting a new key? Is this one of those things where I will need a new ECM and am I forced to go to a Toyota dealer to handle this?
I'm just trying to educate myself on my options here and I don't have any knowledgeable folks around me right now, so any pointing in the right direction is appreciated. I am happy to learn. Thank you, all!
ShadowRabbit is offline   Reply With Quote
Old 03-22-2019, 04:28 PM   #2
alanwagen
dealer
The dealer may be able to cut you a key by the VIN. Give them a call and find out.
Old 04-19-2020, 01:16 AM   #3
TcBryan
TcBryan's Avatar
Drives: 2007 yaris sedan base
I agree with Allenwagen's post. The Access key is a universal blank like you get from Home Depot. If you wish to have a Toyota branded key, ny dealer will gladly cut you as many as you want. Your vehicle does not have a transponder key, so a solid brass key will work just as well as the fancy dealer key for a fraction of the price.
TcBryan is offline   Reply With Quote
Old 05-02-2020, 12:47 PM   #4
jra
Drives: 2015 yaris L
Odd that the key for the ignition doesn't fit the doors? Dealer may be able to cone up with a door key? If not try a lock smith, if you get a door key you can remove the ignition switch and may be able to file the tumblers so the door key fits the ignition too.
jra is offline   Reply With Quote
Old 05-03-2020, 12:07 AM   #5
TcBryan
TcBryan's Avatar
A locksmith can re key the locks for you. The door and trunk lock are a breeze to remove and install.
Yaris 2012 Sedan Key with remote faisalloe General Yaris / Vitz Discussion 5 09-27-2012 10:29 PM
2010 Yaris Sedan - Need Key Programmed to the Immobilizer vst General Yaris / Vitz Discussion 0 04-17-2011 04:29 PM
