Old 05-17-2020, 04:03 PM   #1
Pinchlite
Drives: 2007 yaris HB
Radiator or waterpump?
Started overheating.Popped hood small amount water below radiator on plastic tray.
I looked around best I could and dont see anything dripping.
Should I just go ahead and replace waterpump as its probaly on its way out anyway?
This could take one thing out of the equasion.
Old 05-17-2020, 04:34 PM   #2
nortonfb
Drives: 2007
A radiator leak (I think would be obvious) would have staining around the leaking area.
Water pumps usually have a small puddle (about quarter size).
I would park the car and check for wet area. dry and a put a piece of paper toweling under water pump. Check it a hour later.
nortonfb is offline   Reply With Quote
Old 05-17-2020, 04:35 PM   #3
nortonfb
Drives: 2007
Almost forgot, you can pressure test the rad.
Old 05-17-2020, 04:44 PM   #4
Pinchlite
waterpump
I will try paper thing.
I just ordered a new pump just incase.This car has kinda had it.
I just had starter,alternator,wheel bearing done.
I wont chance this car long distance anymore.
Old 05-18-2020, 07:20 AM   #5
ex-x-fire
Sometimes overheating will push coolant out of the over flow tank. I'd start with a pressure test though.
Old 05-18-2020, 07:34 AM   #6
Pinchlite
I will make appointment.Thanks.
It must of pushed coolant out of overflow because it was about 1 cup of water roughly beneath radiator.
The light jsut flashed and luckily I was real close to home and coasted and light went off.
The cooling fan is working for sure.
I had to top up rad twice in roughly 12 months before this.
I should check WP for play on pulley?
