Old 05-27-2020, 04:22 PM   #1
Netcom
Netcom's Avatar
Drives: NA
Fog light installation question for '15 Yaris
I have a 2015 Yaris LE 5 door built in France. I purchased a fog light kit off of eBay and took it to my local shop to have installed.
The tech found out that my Yaris is already pre-wired for fog lights and after installing the lights and housings themselves it was just a matter of plugging them in.
The technician also noted that the car had a relay and was already wired into the fuse panel.
The only thing he couldn't find was where to plug in the switch. A downloaded wiring diagram shows where the switch itself goes (to the left of the steering wheel by the dash light dimmer) but doesn't show where the plug is.
After a call to Toyota, the tech there said the plug should be taped up to the main wiring harness behind the instrument cluster.
At this point I told my local tech that I would take the car home and see if I can find the plug myself but after removing the instrument cluster I still cannot find a plug anywhere.
Does anybody have any ideas where to look ?
2015 Yaris LE
Netcom is offline   Reply With Quote
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Yaris rear fog lights installation rtayyebi Cosmetic Modifications (Exterior/Interior) 1 11-14-2014 06:21 AM
