Old 08-18-2020, 07:46 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Transmission flush, brake bleeding and oil change
Working down through my routine maintenance checklist.
Transmission service: I've been wondering what the fluid looks like after the transmission has been under heavier load with the turbo. It's been working great with no signs of issues. I had changed out the fluid in the fall (2 drain and fills). The fluid came out clear and clean, with zero debris in it. I strained it to see if there was anything untoward in the fluid. I did one drain and fill and will do another as I have 3 quarts of WS left.
Brake Bleeding: This is what came out, again, like the ATF, no debris or signs of moisture. Pretty clean. This process was done about a year ago. My son helped me by being my brake pumper.
Gotta keep that evil corrosive brake fluid off the hardware.
Front calipers:
No pics of rear wheel cylinder bleeding.
No pics of oil change as those have been seen 1000 times. I used SuperTech 5W30 Full Syn and an OEM filter this time.
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 04:49 PM
