Old 10-26-2020, 07:12 PM   #1
Branderrp
Drives: Yaris 2006 NCP91R
Auto Transmission Leak
So after recently changing the fluid, filter and pan gasket I've noticed a leak but it appears to not be the result of the pan as I've ran my fingers slightly above where the pan meets and felt fluid
It appears to from above through those connections. The second picture is just above the transmission
I'm not too sure if this issue was there before changing the fluid etc.
Anyone have an idea what that could be?
Branderrp is offline   Reply With Quote
Old 10-26-2020, 08:50 PM   #2
ex-x-fire
Could you have spilled some when filling it up?
Old 10-26-2020, 10:24 PM   #3
Branderrp
I'm starting to think it could be a spill
I may leave it for a few days to see how it goes (the rate of leak it's very low)
Do you think I should look out for anything in particular?
Auto transmission leak? mtshum DIY / Maintenance / Service 0 07-24-2020 01:02 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
