Old 08-07-2014, 01:35 AM   #1
MoneyT8
Drives: White Yaris Sedan
What car battery do you use?
My car battery is dying and was looking for a replacement, any recommendations? My current battery is a Duralast which was bought nearly 3 years ago. How does the car battery warranty work? Thanks.
MoneyT8 is offline   Reply With Quote
Old 08-07-2014, 02:11 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I use Costco. When it fails, i just go back to Costco and exchange/return for a new one. Best value for one time buying a battery that will "last" forever.
Check out my Build thread:
Old 08-07-2014, 06:55 AM   #3
bronsin
bronsin's Avatar
I buy the cheapest thing out there and they generally last more than seven years. Even my motorcycle batteries. I guess I live where its not to hot or cold and I drive every day the same 6 miles.
Incidently I was in Pep Boys the other day and the cheapest battery was $115 and there were some over $200!
Old 08-07-2014, 07:56 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Dépends where you live for a battery to last. Hotter the weather, less longer it will last is a rule of thumb.
I always tend to use the cheapest battery out there.. But I'm still on my original Panasonic battery from 2006...
Old 08-07-2014, 02:08 PM   #5
wufai
Drives: Silver Yaris Sedan (4A)
I just purchased a Exide Edge AGM battery for my Yaris, I was using the orginal battery since 2007 and last winter it failed me twice on starting up.
I got the Exide Edge for $135CAD, where a generic battery is selling for $99. I figured the extra $36 for another 4 years is a good investment. I plan on adding a subwoofer to my Yaris and the additional battery I used for charging 2 ipads I figure a better battery will last longer.
wufai is offline   Reply With Quote
Old 08-07-2014, 02:10 PM   #6
The Limo 2
Just changed my battery. Went to Costco and paid $110.(plus tax and enviro fee) Three year replacement then prorated for a total of 100 months.
Roy
The Limo 2 is offline   Reply With Quote
Old 08-07-2014, 11:13 PM   #7
bail_w
Drives: 2007 Toyota Yaris LB
I went with Costco battery as well.
bail_w is offline   Reply With Quote
Old 08-09-2014, 05:22 PM   #8
MoneyT8
So I decided to go with the Costco Battery and when I went in today to buy one the clerk told me it was not available for the 2007 Yaris? I find that hard to believe since the Yaris is a economical car. So I was wondering how did you get one for your Yaris at Costco? Do you have the model number? Thanks
PS I'll probably go with Walmart EverStart.
***Update just got back from Walmart and there batteries are not compatible either; what gives? I'll try DieHard or my Duralast and be done with it.
Old 08-15-2014, 02:45 PM   #9
nookandcrannycar
IllusionX is correct re series 35 being the series that is supposed to be for the Yaris. However, you are also correct...Wal-Mart's Series 35 doesn't fit (stock) in the Yaris. The OEM battery in my 2007 Yaris lasted about 138,000 miles and from 10/7/06 to 9/12(?)/09 (just under 3 years). I went to Wal-Mart to replace it. Their Series 35 wouldn't fit, and they refused to put in any battery at all. They said they could only install the battery that their 'manual' specified, or else they would be 'liable' . I went to Sears. Their Series 35 wouldn't fit either, but they OK'd putting in a Series 26R (1 year guarantee)..their cheapest battery. That battery lasted exactly 3 years to the day and 87.000 + miles. By that time, Sears had eliminated their 1yr Guarantee battery, and the 2yr guarantee battery was $20.00++ more than the previous 1yr battery. Wal-Mart still had a 1yr Guarantee 26R that was the same price the Sears 1yr Guarantee battery had been 3 years before that. I took the car to a different Wal-Mart from the one I'd taken it to 3 years before that. I had to go through the tech trying to put in a series 35 (it didn't fit again...same as 3 years before that), until he then agreed to put in the 26R. That 26R only lasted about 16 months and about 49,000 miles. By that time, I knew CTScott uses the NAPA Legend in his Yarii and decided to get the NAPA Legend.....$121 and change and then $10 to a local shop to put it in. The cost of the previous Sears battery, plus the cost of the Wal-Mart EverStart 3 years later, plus installation for both = literally only a few pennies (less that a dollar) of difference from the $121 and change + $10 installation for the NAPA Legend. The NAPA Legend is well worth it....a great battery. The NAPA Legend series 35 fits in the Yaris. The reason the Wal-Mart series 35 doesn't fit stock isn't that it won't 'sit and have enough clearance', it's that the clamp won't fit over the top of the battery. Some people have customized the clamp to get it to fit, but isn't buying a battery that fits an easier proposition?
Old 08-16-2014, 06:53 PM   #10
MoneyT8
I just went to Pep Boys and bought a Prostart battery that fits perfect and has a 2 year replacement with 72 month pro-rated @ about $95 after core. The next time I just may consider the OEM Toyota Battery, I heard it will last for a very long time and is very dependable. Thanks guys.
Old 08-16-2014, 07:06 PM   #11
IllusionX
You can't really find the Panasonic battery anywhere. Even our local Toyota dealers don't sell then. They actually sell batteries manufactured locally.
Old 08-07-2014, 11:26 PM   #12
I am a big fan of the Napa Legend battery. The 7535 model is a perfect fit.
Old 08-09-2014, 03:58 PM   #13
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Optima Group 35 yellowtop for me. I figured I had one in my Vanagon for 11 years before it finally crapped so I can hope for 5-7 with this one.
07stlYaris is offline   Reply With Quote
Old 08-09-2014, 04:13 PM   #14
IllusionX
It really depends where you live. AZ heat will probably kill the optima with 3-4 years still whole it would last 10 years in NY.
I usually tend to buy the cheapest one at Canadian Tire store... I'll see what I will do with my Yaris as it is still running on its original battery from 2006.
Old 08-28-2014, 06:02 PM   #15
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Another big Optima fan here...
The last red top in my truck lasted 10 years, replaced it with the same kind. When I bought a new truck, I moved it.
What I like about Optimas are that they will NEVER NEVER EVER leak even one tiny drop of acid... even if they're installed upside down.
My 2012 Yaris is still on the factory battery, but when the time comes, it'll get an Optima.
Greg
Old 08-28-2014, 06:37 PM   #16
nookandcrannycar
Greg
Did your purchase occur before or after Optima moved the factory to Mexico? I've heard some horror stories re the made in Mexico Optimas.
Old 10-04-2014, 09:39 PM   #17
alanwagen
did it today
I signed up with Napa and they sent me 10% off coupon and we got the Napa 7535 battery. Around $109 with tax. Good stats, fits perfect. Also if it is good enough for CTScott, it is good enough for me. We did not want to wait for the old one to fail. It was starting to swell as old batteries do and it was 6 years old.
BTW, what do you guys think about battery protectors (felt washers) and synthetic Dielectric grease placed on the terminals after hookup?
Old 10-05-2014, 01:13 AM   #18
aspro
I always grease the terminals. Have been for years on both my daily drivers and work cars. Being in Canada its always good to get some grease on there in the event they get rusted or corroded. I've never had an issue with DE grease on the terminals.
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 03:14 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-02-2009 12:12 AM
