Old 07-20-2018, 02:26 PM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
ECU Swap
I've recently swapped my 2nzfe to 1nzfe.....but the ECU is still the 2nzfe's....i didn't have the time to sort out the wiring of the car.......so far the car is running good....except the car is idling rough, i wanna knw if the ECU can be swapped without any wiring work, like if its a plug and play thing.....though i have the U440 transmission......1nzfe's have the U340 transmission.......need expert opinion
Bony_ahmed is offline   Reply With Quote
Old 12-19-2020, 03:12 PM   #2
Ricfon
Drives: Toyota Yaris 2000
Hola tengo exactamente la misma pregunta, alguno tiene informacion sobre si es plug and play?
Ricfon is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
2zz Swap on Vitz/Yaris SCP90 blindmanwatching Performance Modifications 34 05-17-2015 10:50 AM
