Old 07-18-2019, 07:49 PM   #1
SirDigby
Drives: 2007 yaris 3 door
no HVAC lights, no headlight buzzer
hello. so i removed my aftermarket tachometer, and am getting ready to install my new tachometer. i had the illumination light wired directly into the lower fuse box on old tach. when i was running wires for new illumination, i found a wire tap installed on dimmer adjustment rheostat. i though it might be nice to dim the new tach, so i connected wiring to tap in. the other side was not connected yet, i was just running wiring. after that, i lost HVAC lighting, and speedometer does not dim when turning on headlights. buzzer is not functioning for "lights on warning." i disconnected the installed dimmer switch wire. i have checked all under dash fuses and under hood fuses. i can not seem to find where the issue is. headlights, parking lights, DRL's, tail lights all function normal. i've done a search for this issue, but there is not a clear answer on any posts. i've seen mention of the dimmer switch, and panel 1 and panel 2 fuses, but i can not seem to locate these fuses.
do you have a solution for me?
thanks!
dash lights, hvac lights, no buzzer, no lights
Dashboard lights and exterior park lights going off NXyaris Suggestions - Feedback - Questions 2 09-09-2016 04:46 PM
diy HID projector w/ halo headlight install tmontague DIY / Maintenance / Service 17 02-04-2016 11:34 AM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Headlight Indicator, Gear Lights, AC Lights All Out Hardicus DIY / Maintenance / Service 15 11-09-2013 05:50 AM
headlight liner parking lights... Kioshi Cosmetic Modifications (Exterior/Interior) 9 02-10-2010 03:06 AM
