Old 09-15-2019, 10:19 PM   #1
400 dollar yaris
400 dollar yaris's Avatar
Drives: 2007 Yaris sedan
coolant flush/change clarification
Hello all,
Planning on doing a coolant change next weekend and I have been researching how to do it correctly. I just wanted to go through and post the steps in the order I am planning on doing them to make sure I dont forget anything or mess anything up.
1) open radiator drain plug, Drain fluid, Close plug.
2) open engine block drain plug, Drain fluid, Close plug.
3) refill coolant reservoir with Distilled water until full. Start car and set heat to high. continue to fill reservoir with distilled water until full when cooling system starts to circulate water through cooling system.
4) go for a short drive to increase temp with heat on full blast.
5) let cool down.
6) repeat steps 1 and 2.
7) repeat step 3 with new coolant.
8) Go for a drive and Check reservoir level after drive, fill if needed.
9) monitor level for next week to ensure reservoir is full.
Are these steps correct?
Thanks,
400
400 dollar yaris is offline   Reply With Quote
Homemade tools for coolant change RMcG DIY / Maintenance / Service 5 07-28-2019 08:56 AM
What is a (or the) coorect coolant & amount for a Yaris? RMcG DIY / Maintenance / Service 0 06-19-2019 06:36 PM
Need advice regarding changing coolant Hamster DIY / Maintenance / Service 14 02-04-2019 05:05 AM
Various problems with service at shop (green coolant and accelerator rattling noise) LilyOfTheYaris DIY / Maintenance / Service 4 04-08-2014 11:31 PM
Khameleon Coolant? LilyOfTheYaris DIY / Maintenance / Service 18 04-08-2014 11:27 PM
