Old 09-21-2021, 11:33 AM   #1
expee15
Drives: Toyota Platz 2005
Post Spark plug gap for Toyota Platz 2005 1.0L
Hi to all!
I have tried to search on this forum and rest of the Internet also, but have not found the answer to my specific query.
I have Toyota Platz 2005 1.0L (sedan), manual transmission. I think it is called Yaris Internationally, if I am correct.
I want to know the correct gap for spark plug used in this car. Toyota Platz was available with three engine sizes, 1.0L, 1.3L and 1.5L.
I bought this car as used, so didn't get any owner's manual. The owner’s manual available on the Internet, for this car is for 1.5L engine only. The spark plug gap mentioned for 1.5L car is 0.8mm (0.031”). Now I want to know, will the spark plug gap be the same for 1.0L also? If someone has specific knowledge about the 1.0L variant, kindly tell me the spark plug gap for it.
Also, just for sake of knowledge, wanted to know, what will be the effects, if the gap is little shorter or little wider? Any fuel efficiency?
expee15 is offline   Reply With Quote
Old 09-21-2021, 11:43 AM   #2
bronsin
bronsin's Avatar
The 1 L engine for the Yaris is not sold here in the United States only the 1.5 L. But there may be people who visit this form who would know
In my experience the spark plug gap isn’t terribly important. I had a Harley Davidson motorcycle when I remove the plugs one gap was zero. Someone must’ve dropped the plug before they installed it .
When the engine warmed up it ran perfectly it just ran a little rough until it warmed up.
Do you have Toyota dealers in Pakistan? I bet they would know.
Old 09-22-2021, 06:49 AM   #3
rayfloyd170
Drives: Yaris 2016 1.3 Manual
If you are using 90919-01176 then most likely 0.9mm. Some specs for other brands even says at 0.7mm
References:
https://www.autodoc.co.uk/car-parts/oem/9091901176?
http://www.automobilespare-parts.com...-13575447.html
rayfloyd170 is offline   Reply With Quote
1.0, gap, spark plugs
Spark plug gap? tomm9050 DIY / Maintenance / Service 5 10-24-2015 12:21 AM
Spark plug gap for 04 echo donnysdayoff DIY / Maintenance / Service 2 01-16-2014 09:56 PM
Spark Plug Gap sleey0 Forced Induction Forum 7 09-21-2010 06:47 PM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 06:23 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 11:02 PM
