Old 12-02-2021, 09:58 AM   #1
TerryAdams
Drives: Yaris
Question Rattling Sound
Does anyone know what this annoying rattle is ?
https://www.youtube.com/watch?v=Y9Oc...b_channel=Slim
It mainly does it when in reverse when I lift off the clutch, sometimes in first gear but never when I'm driving around.
Yaris MK2 2008
Thanks
TerryAdams is offline   Reply With Quote
Old 12-02-2021, 10:18 AM   #2
bronsin
bronsin's Avatar
Unfortunately I haven’t a clue but it sounds pretty bad.
Have you taken it to a mechanic?
Old 12-02-2021, 10:22 AM   #3
TerryAdams
Drives: Yaris
I will be going to the mechanic soon yes as I need to replace the rear coil springs. So I'll ask them when I'm there
Could it be the heat shield underneath ? As it does look a bit loose
Old 12-02-2021, 03:49 PM   #4
bronsin
bronsin's Avatar
Definitely does not sound like a heat shield!
Old 12-03-2021, 02:41 AM   #5
TerryAdams
Drives: Yaris
OK. If it was the heat shield it would do it whilst driving right ?
Old 12-03-2021, 04:54 AM   #6
bronsin
bronsin's Avatar
A loose heat shield does in fact rattle while driving. But your noise is much more serious than a heat shield.
You need to consult a mechanic!
Old 12-03-2021, 07:48 AM   #7
TerryAdams
Drives: Yaris
OK thanks. I'm booked in for next week.
Any speculation on what it could be? It only happens when in reverse and the clutch is up.
Old 12-03-2021, 12:09 PM   #8
TerryAdams
Drives: Yaris
I found a thread on it here. Apparently it's the type of exhaust system the yaris has ..
https://yarisworld.com/forums/showthread.php?t=1774
Old 12-13-2021, 11:31 AM   #9
TerryAdams
Drives: Yaris
Mechanic said it was a rubber exhaust mount needed lubrication. Now it's fine
Rattling sound on Yaris when A/C is off Yaris044 DIY / Maintenance / Service 13 09-03-2020 11:42 PM
Rattling sound car running foot on brake ? YodaBird General Yaris / Vitz Discussion 0 04-28-2018 06:55 PM
YARIS 2005 Rattling sound mik23 DIY / Maintenance / Service 6 05-15-2016 05:34 AM
Various problems with service at shop (green coolant and accelerator rattling noise) LilyOfTheYaris DIY / Maintenance / Service 4 04-08-2014 10:31 PM
Rattling sound when using reverse gear Swallow General Yaris / Vitz Discussion 5 06-17-2009 01:47 AM
