Old 02-16-2022, 01:42 PM   #1
RedRide
RedRide's Avatar
New tire valves?
I have an a 2009 Yetis HB that is in great shape.... it has less than 30.000 miles on it .. long story.
The only thing that I have replaced so far was a new battery a few years ago
However, now the lows tire light on the dash says on no matter what the tire pressure is
So, I assume that the battery is dead on at least one tire valve sender
How much would it cost to replace the valves?
Also perhaps there is there an easy way to disconnect the dash light for .low tire pressure? .
Old 02-18-2022, 12:09 PM   #2
RedRide
RedRide's Avatar
Mo one has ever had to replace them?
Old 02-19-2022, 01:10 PM   #3
CrimsonEclipse
Drives: .
You are correct. The battery on one or more of the sensors has probably failed
Replacement goes for around $250-300
There is a bypass for the TPS module.
Can't remember where I found it but it worked.
(I can't post pics for some reason)
CrimsonEclipse is offline   Reply With Quote
Old 02-19-2022, 09:21 PM   #4
ex-x-fire
I'd find a parts store that carries the Autel MX-sensors. See if they can get the tpms codes out through the OBD2 connector and program new sensors for you. Then take them to a tire shop for installation. I tire shop might have autel too. If anything, If you can get the codes I'm sure you could order some programed sensor on e bay.
Old 02-23-2022, 09:55 AM   #5
RedRide
RedRide's Avatar
Thanks for the replies
I will go down to a local privately own tire shop in a few day to see what they can do for me. I have dealt with them in the past and they were great
I just wanted a ball park figure and around $250 seems to be about right fro new TPMS vales installed. from what I can find on the net.
I just did not want to get ripped off. and I'm certainly not going to the Toyota dealer for it.
Old 03-03-2022, 01:36 AM   #6
zimmer
Drives: 2011 Yaris Sedan
The new battery should eliminate any possible failing sensors due to inaccurate voltage.
zimmer is offline   Reply With Quote
Use of a can of tire sealant voided road hazard warranty nookandcrannycar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 02-22-2014 07:49 PM
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
