Old 03-06-2022, 10:32 AM   #1
DaBlueberry
Drives: 2010 Yaris Sedan
2010 Yaris Radio Static
Hello Everyone,
I am NEW to this forum and have an All stock 2010 Yaris Sedan.
After reading several posts about this and doing some investigating, I have found:
That there looks to 3 different Grid sections on the rear window, and 4 wire connection points.
1 the lower with 2 connections, + on driver & - on passenger. Which, ALL lines test good.
2 an upper with 1 connection that goes thru, what I think is a noise filter.
3 a single line that only goes about half way across with 1 connection from the same "noise filter."
I tested the filter I get ground continuity going into the "filter", but nothing out. Which is leading me to believe that the filter is the issue. I could NOT find a replacement after searching several car parts sites.
I am probably missing something, as the outer edge Grid lines are hard to see.
ANY help would be appreciated......
Thanks for your time.
Steve
Last edited by DaBlueberry; 03-11-2022 at 09:31 AM. Reason: Forgot to ask for help.
DaBlueberry is offline   Reply With Quote
2016 yaris radio on 2014 yaris iam_elmanny Third Gen Yaris General Discussion 4 08-20-2019 09:51 AM
