Old 09-29-2018, 06:42 PM   #1
naossoan
Drives: 07 Yaris 3DR
How to remove rear drum, stripped holes
When going to rotate my tires, one of the lug nuts was seized. Long story short, the stud snapped.
I went to get replacements, but I can't get the rear drum off.
The 2 holes that you can screw in 8x1.25 bolts into had a bunch of crud in them. I cleaned them out best I could and tried using them.
The threads in the holes stripped instantly so they are of no use now.
How do I pull the drums off?
2007 Yaris hatchback
Thanks
naossoan is offline   Reply With Quote
Old 09-29-2018, 07:06 PM   #2
Put your wheel back on. With the lugs only slightly loose, drive the car forward and hit the brakes. Now go in reverse and hit the brakes. Repeat a couple of times. This should crack the drum free.
Old 09-29-2018, 08:53 PM   #3
naossoan
so i was able to get the drum off by beating it with a hammer.
I got the stud out by beating it with a hammer as well.
Now how in the hell do I get the new stud in? I got it fished in through the back and through the hole.
I couldn't push it in the hole by hand with the teeth etc so I used a wrench as a washer behind the lug nut and tightened it down with my tire iron.
I am now unable to tighten it anymore while trying to hold the thing in place, since it spins freely and the stud is not even close to being completely in the hole. I do not have any power tools of any kind :(
What do!? :D
Thanks
Old 10-05-2018, 11:19 PM   #4
bairjo
s
Your next project will most likely be replacing the bearing....
Old 09-29-2018, 09:06 PM   #5
tmontague
tmontague's Avatar
Get a ratcheting wrench and a long socket. Tighten the nut down until it pulls the lug all the way through and flush your the hub.
Step 2: get some power tools ;)
Old 09-29-2018, 09:55 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Back to getting the drums off. In our school shop the other day, a few kids were beating, prying, yanking, tugging on a drum to no avail. I suggested that they turn the star adjuster back. They did so and the drum came right off. I showed them how the ebrake shoes (this was a drum in hat rotor) make a groove on the inner surface of the drum and that's why it's hard to get the drum over the shoes.
Old 09-30-2018, 02:34 AM   #7
naossoan
So I was able to get the drum off.
The drum was spinning freely so I assumed there was no issue with the pads dragging or getting stuck on it so I didn't mess with the star screw adjuster.
I kept hitting the brake drum on the front face of it near all the bolts while spinning it around. Eventually I shocked it enough and was able to pull it off.
As for tightening the slug I was able to do it by bringing my wheel up close and under the brake and using another tool wedged in the wheel spokes add the hub to stop it from turning while I tightened down a nut to pull the slug into the hole.
I'm just glad that Toyota didn't design the thing so it is impossible to get the slugs out without doing a whoooole bunch of other work. There was enough space behind the plate to wiggle the slugs in and out so that was great.
Old 09-30-2018, 07:37 AM   #8
06YarisRS
Yes, There's a little depression in the backing plate that allows for easy stud removal. I learned this from other members when I installed the longer studs for my H&R 10 mm wheel spacers. I was lucky to have access to our school shop air tools which made seating the studs child's play.
Another quick school autoshop story: A couple of kids were experiencing trouble getting the studs out past the backing plate of a 1/2 ton truck. One of them grabbed the torches and cut a little 'window' in the backing plate to take the stud out. Inadvertently, he cut out the shoe retaining pin slot. That car got bolted back up without any ebrake parts and a backing plate had to be ordered. While things like this are unfortunate, can be costly, and happen because of a low teacher-to-student ratio, these are learnings that are firmly entrenched, generally not having to be experienced a second time.
Congrats on the getting the job done!
Old 09-22-2024, 10:36 AM   #9
HDS
Drives: 07 Yaris, Saab 900 Turbo
This is ticking me off can't find the access hole for the star adjuster on my yaris. It's a euro diesel from 07 so maybe that's the reason.
HDS is offline   Reply With Quote
Old 09-22-2024, 10:46 AM   #10
HDS
This is what it looks like for me yeah it's crusty, 422000km on salty roads.
Stripped E10 Torx Bolts trying to Remove Seats IMAMEX DIY / Maintenance / Service 5 11-08-2016 08:28 AM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
How to remove rear speaker panel on a Liftback? W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 7 11-25-2006 01:45 AM
