Drives: Yaris Icon Tech Join Date: Dec 2022
Front Suspension Front Ball Joints Sweating!
Hi Everyone,
I’m new on this forum. I wish to pick your brains. My 2017 Yaris Icon Tech (80,500 miles) is making crunching noises whenever I go over an uneven part of the road and humps. My local Toyota dealer in Watford said, “The front ball joints are sweating”. The repair bill is £1131.67. Shouldn’t this be covered under warranty given that every service from new (9 services) have been carried out by them? They’re saying it’s wear & tear. Please let me know your thoughts. Regards. IftyH |
In The US Toyota warranty is 36,000 miles or 36 months which ever comes first.
So based on that your car would be out of warranty.
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
What? Sweaty balls?
https://youtu.be/bPpcfH_HHH8 |
#4 | |
![]() ![]() ![]() Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
If they are you can replace them yourself fairly easily or you can buy an entire new control arm with ball joint and new bushings while there for not that much more money aftermarket. |
![]() Drives: yaris Join Date: Nov 2018
That's a bit ridiculous but that's probably the dealer quoting you for two entire control arms since toyota doesn't sell the balljoints separately and they wouldn't just do one side.
Balljoints are cheap for these cars and very easy to press in and out (50$ + you can go rent out a balljoint press for free at a parts store) Independent shop shouldn't charge you over 200$ to replace one of them. For a 2017 car with under 100k, your control arms probably still have a lot of life in them so long as the bushings aren't cracked |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Shouldn't be covered under warranty. You've gone more than 3 times around earth if you'd have traveled in a straight line
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | 01-25-2026 12:51 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Front and Rear Suspension | nisyota | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-27-2009 01:41 AM |
| Front end suspension making "Creaking Door"noise! Need help! | Syroyizhka | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 04-03-2009 07:55 AM |
| Torque Settings, front suspension | Nimble | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-21-2007 01:00 PM |
