Drives: Toyota Yaris 2006 Join Date: Mar 2023
Loss of Power in the middle of Driving after Car gets driven for an hour or more
Hi Folks,
I have got 2007 Toy Yaris 1.3L...Fot past few months, it is doing a weird thing...It starts well, runs well for a while and then in the middle of driving, it loses the Power and no matter how hard I press the Acceralator, The Car just drives at 5km/hour speed...Then If I wait for 10 minutes and restart the Car then it runs fine for some time until it repeats the same thing after a while. Changed the Fuel Filter, Ignition Coils, Spark Plugs and MAF Sensor...But still the Car does the same loss of Power... Did someone else had similar issue with Yaris in the past...If so, What do u think could be the culprit...? Could it be a Bad Throttle Body which gets Stuck closed at the time of happening or Could it be the ECU as well...? Thoughts ? |
verify your not losing fuel pump pressure
swapping out the TB would be a good idea as well unless youve got an imobilizer i doubt the ecu is at fault what codes is it throwing?...does the car have ABS/traction...some 07s do depending on market and if they get tripped via codes it goes into "limp in mode" and will do exactly as described...typical cause is o2 sensors |
Sounds like it’s in limp home mood. They must be codes get a code reader. No check engine light?
#4 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
id second the upstream o2 as well...maybe codes just havnt popped for some reason
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| What Car Mechanics Don't Want You to Know!! | daddz07 | DIY / Maintenance / Service | 16 | 04-17-2011 10:10 PM |
| How to Be a Street Racer - General Life Guide | MDF | Off-topic / Other Cars / Everything else Discussions | 7 | 03-19-2007 12:49 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 10:58 PM |
