Old 11-08-2021, 11:39 AM   #1
Ennea
Drives: 2009 Yaris (Sedan 4D)
Dashboard lights on (engine coolant & traction)
Hi everyone. I'm a new car owner and have purchased a 09 Yaris last month. I got two dashboard lights come on when I start the car:
1. Blue Coolant Temperature Light - goes on every time I start the car. After about a 1-2 minute drive, goes away. I don't remember this being an issue when I test drove the car a month ago. Since then, it spent about 3 weeks standing and not being driven in Southern Vermont.
2. Traction light is flashing all the time.
Thanks for any advice, in advance, as I'm a newbie.
Ennea is offline   Reply With Quote
Old 11-08-2021, 12:57 PM   #2
Scooter M'Gee
Scooter M'Gee's Avatar
Drives: 2017 Yaris L
The "cool" coolant light goes out when the car gets close to operating temp. Nothing to be concerned with.
The flashing Tire Pressure Monitoring Sensor light is something to take note of. It is either telling you one or more of your tires are underinflated or you have had a sensor in one of the wheels fail to communicate with the car.
Scooter M'Gee is offline   Reply With Quote
Old 11-08-2021, 01:04 PM   #3
thetut
Drives: 2007 4dr sedan
The lights I see are
1. COOL - the engine temperature is below normal operating temperature. You didn't see it during your test drive as the engine was probably warm at the time. You will notice that the transmission will not shift into top gear until this light goes out.
2. The red light is your seat belt light
3. The yellow light is your Tire Pressure Monitor System (TPMS). Check your tire pressure and if all are at specification then have someone check each wheel sensor.
thetut is offline   Reply With Quote
Old 11-09-2021, 12:11 PM   #4
Ennea
Thanks.
About the "cool" engine temperature light: the light goes on every single time I start the car. I've driven cars for 20 years and I've never seen a car do this every single time, even when the temperature outside is not that low. That shouldn't be happening constantly, shout it?
Old 11-09-2021, 02:25 PM   #5
Scooter M'Gee
Subaru's do this as well. It all depends on if a vehicle is equipped with such a light. The light will be lit at every cold start. It's supposed to come on. It's totally normal.
Old 11-09-2021, 04:10 PM   #6
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It even comes on in the middle of Australian summer. Think of it like the needle of a temperature gauge being below the "normal" temperature range. Basically, it indicates the engine has not yet warmed up, and you should drive reasonably calmly until it goes out.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-09-2021, 04:08 PM   #7
BLH
Drives: 2007 Yaris Sedan
The Cool LED lights in my 2007. If the coolant temperature is below 130 degrees on my Scanguage.
If I stop and run some errands and the coolant is still above 130 degrees it does not light again. If it has cooled down to less than 130 degrees it will light again.
BLH is offline   Reply With Quote
Old 11-17-2021, 10:52 AM   #8
Ennea
Thanks for the input, guys.
Old 08-29-2024, 12:10 AM   #9
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
The blue temperature light in my car stays on, even when the engine is at operating temperature. It should turn off around 55°c (131°f), but instead it turns off randomly. Sometimes it even turns back on again. The scangauge reads regular operating engine temperatures, so I know for sure it is not the sensor. The car runs perfectly, no problems what so ever but it called my atention the fact that the light remains on.
Anyone with the same symptoms by any chances?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
dashboard light, engine coolant, traction control light
Dashboard lights and exterior park lights going off NXyaris Suggestions - Feedback - Questions 2 09-09-2016 04:46 PM
Need help on engine coolant check Nahid DIY / Maintenance / Service 2 05-24-2016 12:33 PM
Dashboard, tail light, and radio lights aren't working! vinooooo93 DIY / Maintenance / Service 8 10-31-2014 08:21 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 12:26 AM
