Old 10-26-2024, 09:01 PM   #1
JackBurton
Drives: 2008 Yaris
Crank, no start. Running out of ideas.
Hi all.
2008 Yaris sedan.
Daughter went to go somewhere yesterday but the car would not start.
Cranked fine, but sounded like it was out of gas (it’s not).
I couldn’t hear the pump running, but some are pretty quiet and I have no prior experience with this car.
Only code was for crank sensor, and I figured that was it, as it would cause this issue, but that wasnt it.
Checked at the fuel pump, no power with key on, but only I have 8 volts at one wire all the time, key on it off.
Found a few threads here and went through a few things.
Integration relay shows 301 ohms between 2-3, post said under 100, but will trigger relay with 9v battery.
C/opn relay testing was a little odd.
4b-9 to 4e-5 showed 167.1 ohms, Post said should be under 100.
4a-8 to 4b-11 showed 12v
4b-9 showed 12v when ignition on
4e-5 showed no change when ignition on. Did not go to ground.
Would that mean the ECM is bad?
Can they do that that quick, from working fine one day to not the next?
What do I need to know, if that’s it, to get a replacement?
Thanks for any help.
JackBurton is offline   Reply With Quote
To start or not to start? Doix DIY / Maintenance / Service 11 12-10-2023 08:30 PM
Remote Start Bug, please help jeeper5usa In Car Entertainment + Electronics (audio / video / alarm) 5 01-02-2014 08:36 PM
I Need To Start Running Again blacksan Off-topic / Other Cars / Everything else Discussions 0 08-07-2007 07:57 PM
