Old 07-24-2007, 02:55 AM   #1
wushumasterku
Drives: 06 White LE HB 5spd
still wheel confused..
after looking at garage pics and reading stuff here, still confused and don't want to get the wrong sizes
should i go with df210 and get 15inch rims? (how about 16's)
or
go with nf210 and get 16inch?
what size tires...???
wushumasterku is offline   Reply With Quote
Old 07-24-2007, 04:04 AM   #2
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
People have DF's all the way up to 17 inch rims and up. They have the dfferent sizes cause people like to run them on the track and people like me just for everyday driving dont care as long as the rim and tire lasts if you drill a pothole.
If you take the height if a rim and a low profile tire they are about the same as the 15 or 14 inch wheel and tires with a taller side wall . The problems I believe people are running into is the size of the tires and the offset of the wheels causing rubbing. I had 17 x7 offset +40mm with 215/40/17 tires. The only rubbing was in the back. The outside of the sidewall barely rubber the inside of the wheel well.
Old 07-24-2007, 04:13 PM   #3
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
I too have 17 x 7 offset +40 with 215/40/17 tires and the only rubbing I had was the same as slvryaris. However rubbing only occured when I had a full car. When driving solo I haven't had rubbing problems on hard turns, deep dips, or high speed bumps. I'm scheduled for an alighment next week(been lazy) so hopefully that small problem will be fixed.
eijikikimaru is offline   Reply With Quote
Old 07-24-2007, 04:21 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
or
everything depends on what you like, what you can afford, and what kind of driving you plan on doing with them... click on my signature for some tire options from 14-20 inch wheel sizes
Old 07-24-2007, 11:33 PM   #5
CKMotorsport
CKMotorsport's Avatar
Drives: Yaris
or
here I got the picture for 16 x 7 SSR Type C Gunmetallic
Tire Size Michelin Pilot Preceda II 205/50/16. I think its a perfect combination.
But for myself, I would preffer to use DF210 and 15inch on 195/55/15 tires. or better use Sustec Pro NF
but its all up 2 u.
CKMotorsport is offline   Reply With Quote
Old 07-25-2007, 12:37 AM   #6
ya_RS
ya_RS's Avatar
Drives: 07 RS
but its all up 2 u.
do u know the drop on this?? looks like the eibach/trd kit
Honda to Toyota... lets see how this plays out
ya_RS is offline   Reply With Quote
Old 07-28-2007, 09:02 PM   #7
wushumasterku
yea, looks good but what drop is this? do you know?
Old 07-29-2007, 02:35 AM   #8
wushumasterku
but its all up 2 u.
why do you prefer the df and 195/55/15?
actually which one gives better mileage?
Old 07-25-2007, 01:45 AM   #9
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
or
welcome to the club.. , i've been in your position before...
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 07-25-2007, 05:25 PM   #10
ya_RS
ya_RS's Avatar
Drives: 07 RS
there is going to be many factors involved to get a great setup...
for example http://www.yarisworld.com/forums/showthread.php?t=7489
With RIMS.....the bottom line here is
--get as close as you can to your tire height
--get an offset that wont let the rim sit to far in or out the wheel well
--get lowered to your desired height...
after lowereing.... and if there is rubbing
--roll fender
--the rubbing is due to a high bound/rebound on the spring so get aftermarket shocks to stiffen the ride
--rubbing could be in the well due to wrong offset and its hitting the inside of the wheel well
and there you have a lowered car with the rims you want
and there are other / many other sulutions and factors .... youy can even go extreme and have a WIDE-body vitz
Old 07-26-2007, 12:19 AM   #11
Indianspringsaz
Drives: 07 Bitchin Blue HB
or
I am in the same boat as you. Want to go with NF's and 16's.
Can you recommend any gallerys to look at?
Indianspringsaz is offline   Reply With Quote
Old 07-28-2007, 09:25 PM   #12
ya_RS
ya_RS's Avatar
Drives: 07 RS
naw... its a car from Japan cause it has the rear disc... you know they alwasy get the advanced stuff... lucky guys
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
WANTED: 4 Wheel Covers galaxyhillvt Items for Sale by private party 2 07-11-2007 04:05 PM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 11:38 AM
