![]() Drives: 2007 Toyota Yairs Join Date: Jul 2007
Hatchback liftgate post (pneumatic)
I was just loading my '07 Yaris and tried to close the hatch when I heard a "DUNK" and it fell shut. Inspection revealed that the left pneumatic arm's anchor (on the trunk side) had popped out.
Has anyone had this happen? Better yet, anyone have an easy fix? It'd be great not to have the trunk drop on my head every time I'm rummaging around. Here's a picture of the snapped-off piece in question. It looks like my pneumatic arm froze - I can't manipulate it manually unlike the still-operating one. http://phreque.com/_tempor/DSC02233.JPG Last edited by Echostatic; 04-17-2012 at 04:22 PM. |
Pics? Can't quite visualize what you say has happened.
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Lending a helping hand...
Sorry for the large image, just saved and up'd
Yikes. There's no easy fix for that. First time I've seen it happen. Good luck.
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Wow that is not good lol
My guess is it looks like it will have to be welded back in. |
advocatus diaboli
It wouldn't take much to get that welded up...that's pretty crazy that it popped out like that. It won't be pretty, but it won't happen again either.
DAT'S RIGHT I GOTz 2
Just watch when you decide to get it welded might have to remove rear glass to prevent it getting shattered
or you could just carry a broomstick to keep rear up n open
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
I would try to repair it using screws,, something like two M5 or M6 bolts on each side
Glad I could blaze a trail with a new failure :) Thanks for the suggestions, all. Looks like I'll be keeping the parts handy and going for a weld when the droopy liftgate gets on my nerves!
Solved. I bought these (just in the nick of time, looks like. Currently unavailable): http://www.amazon.com/gp/product/B00...ls_o00_s00_i00
...and a local body shop charged $100 to re-weld the detached piece and slap on the new trunk struts. All said and done, $154 and it's back to working like new. Not as terrible as it could've been! |
There is a great vendor that has been around for many years that sells qualty lift supports for most any vehicle.......... " "lifttsupportsdepot.com"
http://www.autopartsbylou.com/index.php People who have ordered from them say the quality is first rate and, the prices are low. They also sell all kinds of hardware associated with lift supports. Here are their supports for the Yaris. http://www.autopartsbylou.com/lift-s...=mmy&x=18&y=11 Be shure to read the FAQs as it has a lot of info about supports in general that is usefull no matter where you purchase them. BTW, those type of supports are much stronger than some people realize and there is a lot of stress on the mounts when compressing. It's probably best to always lower a hatch gently when closing. Last edited by RedRide; 05-18-2012 at 05:50 PM. |
![]() ![]() Drives: 2008 yaris hb Join Date: Mar 2011
Use a big molly bolt to hold the bracket. That is ugly
good luck |
![]() ![]() Drives: 2007 2DR Liftback Join Date: Oct 2011
I just replaced mine on my 2007 hatchback. Bought the two new ones from the above -- www.autopartsbylou.com -- for US$40.93 including shipping, and they arrived quickly. They were made in Turkey.
I used one of these to support the hatch while replacing the lifts: http://www.harborfreight.com/2-in-1-...bar-66172.html The new lifts are much stronger than old, at least for now. I assume they will break in a bit with time. |
![]() Drives: 2007 Yaris Hatchback Join Date: Oct 2008
This happened today 1-03-2015 to my wife's Yaris. The left side broke completely off and the right side broke one weld. I drilled holes away from the broken part and put sheet metal screws in it.
We will see what happens. Van |
2ZR swap. DO IT! Ask how!
Add me to the list of casualties for this failure mode. I'll probably just use JB weld after removing a little bit of paint to get good adhesion. What a pain in the arse!
![]() Drives: 2009 Hatchback Join Date: Feb 2011
My left side (second one now!) just went today - happy new year to me
First one snapped in July of 2016 and at the time I took it to a body shop for repair. What they did was drill through two holes on the bracket and then drill another two holes in the boot lid so they could then secure the bracket using 2x M6 hex nut and bolts. I might attempt the same repair myself but the only thing I'm unsure about is how to tighten the nuts on the inside? Or perhaps I just give them the repeat business lol In hindsight, it might have been cheaper just to get a whole new hatchback from the breakers! |
I guess this can be fixed easily with rivets.
I hate rivets... but from time to time they do make one's life easier. |
Will rivets be strong enough to hold the bracket?
| 3 Door Hatchback Questions | Dorkinheimer | General Yaris / Vitz Discussion | 12 | 01-16-2012 06:30 PM |
| Do any other Toyota front seats have same bolt pattern as Yaris? | ScottFern | DIY / Maintenance / Service | 18 | 07-02-2007 12:44 PM |
| Install sedan integrated stereo in hatchback? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-22-2007 06:25 PM |
| Seeking Hatchback owners to help with parts test | why_14 | General Yaris / Vitz Discussion | 2 | 12-06-2006 12:16 AM |
| Yaris Hatchback Clearance Height | Ryu | General Yaris / Vitz Discussion | 7 | 11-28-2006 02:35 AM |
