Old 11-03-2008, 06:01 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
blitz throttle controller does it work..
whats the review on this from the yaris owners...anyone.
economy= mpg ?
normal =
sp1= mpg ?
sp2= mpg ?
sp3= mpg ?
Old 11-03-2008, 06:22 PM   #2
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
if im not mistaken the only one who has one is echo hrs who currently doesnt have a running yaris bcuz of the blitz supercharger.
maybe he or cali should send me one to test out .
i'd like to know how it would work with a modified Tb setup since i have the corolla TB from a 1zz and not the stock TB
all its going to do is boost the signal from the pedal to TB. allowing for quicker reaction times off the line if u were drag racing or just a faster responding TB. i dont believe theres a boost in power. just the same power sooner
Old 11-03-2008, 06:30 PM   #3
marcus
toyota
marcus's Avatar
cool... hey cali send whopee the piece for trial.....
Old 11-03-2008, 06:38 PM   #4
whooppee777
see cali? marcus approves
Old 11-03-2008, 07:03 PM   #5
marcus
toyota
marcus's Avatar
after an hour of researching.. the only thing i came up with was it double.triple,then quadruple the percentage of gas feed. so pressing gas 10% with sp1 your like pressing is at 2x the %,sp2 3x and sp3 4x.the %....
Old 12-16-2008, 12:50 PM   #6
marcus
toyota
marcus's Avatar
well does this blitz controller work??
Old 12-16-2008, 01:09 PM   #7
Malaya1221
super duper M*******TOR
Malaya1221's Avatar
yaris t-sport has one...pivot is also making one for a very reasonable price but only has 3 settings, think!
Old 12-16-2008, 01:32 PM   #8
It works, but you have to understand what it does.
It does NOT make your car faster (0-60, 1/4 mi., etc.) or affect the actual horsepower at all. It does not open up the throttle farther than it already opens. It does not affect fuel mixture or delivery to the cylinders.
It simply changes the the message from the pedal to the ECU to make it think that you are pressing the pedal down farther than you are.
It makes the car FEEL faster in normal driving, BUT... IF you just drove by slamming your foot to the floor, you'd never ever notice the function of this device.
Does that help explain it?
Old 12-16-2008, 06:06 PM   #9
marcus
toyota
marcus's Avatar
thatll do it!! thanks.
Old 12-16-2008, 04:54 PM   #10
facebreaker1212
Drives: '08 Yaris LB
Does it make it feel more like a cable? That's what i am looking for.
facebreaker1212 is offline   Reply With Quote
Old 12-16-2008, 06:38 PM   #11
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
the controller arrived at work. i will install it tonight after my shift ends. ill let you know the results. ill also be doing an oil change to royal purple synthetic as well at the same time
Old 12-16-2008, 09:29 PM   #12
mikenacarato
SIPNDEW
Drives: 15 STI
controller is installed but i still have 2 hrs till i can leave to test drive it. :( i still have to do my oil change too. i thought the controller plugged into the throttle body but it connects to the tps on the pedal. so no going through the firewall needed!
Old 12-16-2008, 11:13 PM   #13
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
UPDATE!?
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 12-16-2008, 10:08 PM   #14
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
I was told by YarisDarkness that it lessens the lag felt with the drive-by-wire throttle by telling the ECU that the throttle pedal is pressed further than it actually is.
For Blitz supercharged engines, it is most useful if you're setting your S/C for 50% throttle cut-in. The car would normally be its normal sluggish self until your pedal reaches 50% when the S/C kicks in abruptly. With the trottle controller, the throttle response is more responsive so when the S/C kicks in at 50% you won't feel as much of a lurch.
I tend to run my S/C at 20% throttle cut-in at the moment so the Throttle controller would not be as noticeable. I spend most of my time with my rear-view mirror air freshener hanging horizontally due to the massive acceleration.
Old 12-16-2008, 11:06 PM   #15
it is an extremely easy install, just plugs in inside the cabin.
Old 12-16-2008, 11:47 PM   #16
mikenacarato
SIPNDEW
Drives: 15 STI
30 mins till i leave. then oil change will take a few mins. then test drive on the way home. then ill update haha.
Old 12-17-2008, 12:29 AM   #17
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
sooooooooooo update?
Old 12-17-2008, 02:16 AM   #18
mikenacarato
SIPNDEW
Drives: 15 STI
all i can say is wow. the throttle is so much more responsive down low. when taking off in sp3 mode its like driving a whole new car. not to mention the 1st to 2nd shifts feel a lot torquier (sp?). Definately a good mod once you have done other stuff. I have not dont anything engine wise except for pulleys. i know the 2nd pic may be hard to see where it is but its nice and cleanly installed. :)
Blitz s/c info cont'd cali yaris Forced Induction Forum 36 03-10-2009 12:33 AM
FS: $250 + Shipping - BRAND NEW Blitz R-FIT (Fuel Intensity Controller) Ran Kizama Items for Sale by private party 8 09-06-2007 04:26 PM
My Work, Your Work - Stories and Fun SmallCarGuy Off-topic / Other Cars / Everything else Discussions 0 09-02-2007 07:43 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
