![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Hot key
Is your key hot when you pull it out of the ignition?
I travel quite a bit so I drive lots of different rental cars and I've never noticed a hot key. My Jeep key isn't hot when I pull it out.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Mine usually is.
A few questions.
Do you have the heater on? Is the key/dash in direct sunlight? Is the ignition warm to touch before you start your car? It could just be one of those three things, just like when you get in on a hot day and the metal on the seat belts is hot like fire!
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
Drives: Toyota Yaris Join Date: Dec 2008
On my 2007 Yaris the ignition key is sometimes too hot to touch. Does anyone else have this problem?
Audio Junky
my key is wrapped in rubber.... it's never felt warm, not even when temps were 106F here last week. I have tinted windows and use a windshield screen (side note).
Drives: 2010 Yaris 4 door sedan Join Date: May 2010
Yes. Just purchased a 2010 Yaris 4 door sedan. It does not happen on short rides. However, when I drove the car for 2 continuous hours at highway speeds, the ignition key and the metal tumbler that the key inserts into were quite hot. Brought it into the Toyota Service Dept. They said the ignition voltage in my ignition is within specification and that many cars get hot keys and ignition cylinders. I have trouble believing that a hot key is anything but abnormal. I already feel that I have a car that might have a serious problem brewing. Has anyone had a hot key and ignition cylinder lead to a serious problem?
![]() ![]() ![]() Drives: 08 Yaris Join Date: Oct 2008
My key was hot when here was 38 decree C = 100F+
-_-
RIP Yaris, I will miss your superb handling a lot. darkmoon87's picture thread http://www.yarisworld.com/forums/showthread.php?t=10013 |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Both of my Yarises makes the keys very hot after driving. Sometimes too hot to touch.
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I've had keys get hot but usually it's because the ignition got really hot in the sun and transferred heat to the key... I haven't noticed it getting hot on normal temp days... I'll have to check it to see
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
Mine has never been bothersome.
Mine is a bit warm at times...
just never enough to post a thread about it :p |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Just checked mine...leaving from work yesterday: 95 degrees before starting vehicle, drove home...80 degrees. This morning: 88 degrees before starting, 84 degrees when I got to work.
I ♥ Yaris
Weird... Hey I've seen some cars (not sure about yari) have lighted ignitions, which might heat up the key...but I cannot imagine why your key would get hot... kinda worrisome...
#14 |
![]() Drives: 2008 Flint Mica Yaris Sedan Join Date: Jan 2010
My key is not and has never been (even after 16+ hours of driving) too hot to touch. I live in Georgia where temps regularly hit 95+ in the summer. I use the key without the rubber protector and it's still plenty cool enough to pull out and touch comfortably.
#15 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
2001 honda civic, key is always hot coming out of the ignition, whether at night or day, hot or cold...... im the original owner (less the parents)....
#16 |
should have opted for the COLD KEY package when you purchased car.....
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#17 |
Hmm sounds like trouble.
#18 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Its probably related to the blinker fluidl
| Flat Key | MadMax | General Yaris / Vitz Discussion | 24 | 11-07-2008 06:40 PM |
| Aftermarket Key Blanks | bearda | Cosmetic Modifications (Exterior/Interior) | 6 | 07-01-2007 06:45 PM |
| Key less Entry | Deonnei | General Yaris / Vitz Discussion | 3 | 03-19-2007 07:32 AM |
| HOT IMPORT NIGHTS MIAMI | elsteverino889 | Off-topic / Other Cars / Everything else Discussions | 0 | 12-05-2006 08:11 PM |
| remote and key not together as 1 | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 10-20-2006 12:23 AM |
