View Poll Results: Handbrake use (Manual vs. Auto)
Manual - Yes I use the handbrake 29 63.04%
Manual - No I don't use the handbrake 2 4.35%
Auto - Yes I use the handbrake 8 17.39%
Auto - No I don't use the handbrake 7 15.22%
Voters: 46. You may not vote on this poll
Old 07-25-2006, 06:07 PM   #1
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Handbrake question (Manual vs. Auto)
I just want to know who here actually uses their handbrake when parked. I have heard both ways on wheather or not to use it.
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 07-25-2006, 06:11 PM   #2
田中秀樹
Drives: SW20
it always up when i park any car either automatic or manual.
田中秀樹 is offline   Reply With Quote
Old 07-25-2006, 06:30 PM   #3
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
My cars that are manual, YES.
My cars that are auto, NO.
Old 07-25-2006, 06:34 PM   #4
Chaad32
Chaad32's Avatar
I did the same thing with my manuals. I also parked out of ger on my manuals though.
2007 Liftback
Blazing Blue
Old 07-25-2006, 06:35 PM   #5
PixieDawn
Drives: Yaris 2007, Eclipse 2000
I do the same thing out of gear, with ebrake
PixieDawn is offline   Reply With Quote
Old 07-25-2006, 06:38 PM   #6
Chaad32
Chaad32's Avatar
I was told this was the way to do it. My real concern is that I park on a "hill" sometimes (not a real hill, just at a slight incline). I was worried that when I go to leave the next day and I shift to Reverse it may be hard on the tranny because of the fact that when I put it in park the night before and then let off the brake it rool forward a little (maby 0.5 - 1 inch) and this causes it to shift hard into reverse. This has happened on a lot of cars that I have owned. Anyone else ever heard of this?
2007 Liftback
Blazing Blue
Old 07-25-2006, 07:52 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Yup I have too that is why when I park on any incline I place the car in the opposite gear that it is facing plus use the parking brake...other than that I always go nuetral and P brake with every manual that I drive...my wife however does not and that is why she is not allowed to drive my car.
Old 07-25-2006, 07:24 PM   #8
Boo
Boo's Avatar
Drives: PW Yaris LB AT
I will do the handbrake + steer against the curb when it is incline.
When I park on flat, I will just leave the handbrake off. Since I think the gear is good enough to stop the car from rolling.
Boo is offline   Reply With Quote
Old 07-25-2006, 07:39 PM   #9
rstb88
rstb88's Avatar
Drives: Silver Hatchback
I use the handbrake on hills, or if i park really close to a car and don't want the possibility of rolling into the other car. And emergency slow downs.
"Automatic carwashes are like Hookers........are you sure you want to use it next???? (Jer)"
rstb88 is offline   Reply With Quote
Old 07-25-2006, 08:03 PM   #10
riceboy
Drives: icebox
Manual w/ left in gear and ebrake...
Auto w/ Park and ebrake...
I think the rule of thumb is that you should either always use the ebrake, or never use it at all.
riceboy is offline   Reply With Quote
Old 07-25-2006, 08:32 PM   #11
swng
swng's Avatar
Drives: 06 3-dr auto RS
I have an auto and I always use the handbrake when I park. I have been told (source forgetten) that the handbrake can do some self adjustment to compensate for wear and tear. The automatic adjustment can only be done when the handbrake is used.
swng is offline   Reply With Quote
Old 07-25-2006, 08:38 PM   #12
rstb88
rstb88's Avatar
the auto adjuster is on the rear brakes but has nothing to do with the hand brake itself. if you go in reverse and do a series of quick stops(don't have to go fast) it cause the star adjuster in the drum to click one notch per stop, which adjusts the pads to sit correctly against the drum in the even of braking
Old 07-26-2006, 05:00 PM   #13
swng
swng's Avatar
But you may also use the handbrake to achieve that, right?
Please see: http://www.echodrivers.com/forums/vi...t=6455&start=0.
I am not trying to debate as (after reading the information you wrote) I have learned that the rear brake self adjuster has nothing to do with the handbrake itself. Thanks for that. I just think the information in the link may be relevant and may interest other members discussing on this thread.
Simply put, using the handbrake for parking may result in some good side effects which may include rear brake self adjustment.
As for whether the Yaris has a self adjusting handbrake, now I am not so sure. Probably some may have that though (please see the last post done on 06 Jan 06 through the quoted link).
Note: We have members from many parts of the world and they drive different versions of the Yaris. It's so hard to cover all bases .
Old 07-25-2006, 09:01 PM   #14
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
manual some times
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 07-25-2006, 09:15 PM   #15
MWill517
MWill517's Avatar
Drives: '07 Yaris Sedan Barcelona Red
Seems I read in the Owners manual "not" to use the e-brake in freezing / icey conditions. As it could freeze and not release. Being in Georgia, I dont think I will ever have that problem. So it is always the e-brake for me.
MWill517 is offline   Reply With Quote
Old 07-25-2006, 10:06 PM   #16
ChinoCharles
Drives: LB
I use the handbrake when taking 90+ degree turns at 40+ MPH, but only when I'm bored. Does that count?
I usually just park and put the hand brake on. If I'm on ANY kind of hill, its in gear too. Funny story...
Went to work and parked my 5-speed 1994 Mitsubishi Eclipse. There is literally no discernable incline in this lot... it might as well be a glass table. Well, I put my hand brake on 80% of the way, but I thought it was all the way up. Anyway, I went into work and a couple hours later someone came in and told me my car was in the grass and I had to go move it out. It rolled 30 feet across the lot and into a field. Lesson learned... if you want to leave your car out of gear, fine, but make sure the hand brake is on first! Ever since I try ripping the hand brake off when I engage it. Better safe than sorry, no?
Old 07-25-2006, 11:39 PM   #17
TRD_Yaris
Yarii Hunter
TRD_Yaris's Avatar
Drives: 2007 Yaris Liftback and S13's
I'm all about the e-brake on either Manual or Auto transmission.
"the transmission isn't a kickstand" <--- Greg from Dharma and Greg...
Thanks for all the help over the years, YarisWorld!!!
TRD_Yaris is offline   Reply With Quote
Old 07-26-2006, 12:02 AM   #18
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
75% of the time YES
BTW it's an auto
07WYarisRS is offline   Reply With Quote
Manual shifter Mod.... hoahmaru Cosmetic Modifications (Exterior/Interior) 28 04-07-2014 05:05 PM
Is the 2006 Yaris Manual stick leather wrapped or not? hoahmaru General Yaris / Vitz Discussion 21 10-30-2008 08:14 AM
Finally drove the manual! drdavidr4u General Yaris / Vitz Discussion 2 06-14-2006 08:32 PM
No Option Combination #B for Manual Liftback???? Chickon New YARIS Purchase Forum 22 05-20-2006 12:49 AM
