Old 11-16-2008, 02:37 AM   #1
mhkritzinger
Drives: 1.8 3dr Yaris TS
Advice on Pioneer AVH-P4000DVD instalation!!
Hello....
I have a 2006 Yaris Spirit with a factory fitted cd player (Silver one that is build into the dash) and i was wondering if it can be possible to convert that to a Pioneer AVH-P4000DVD?? If someone have pics that would be awsome!
Thanx alot for your time!
mhkritzinger is offline   Reply With Quote
Old 11-16-2008, 03:34 AM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
so you have a intergrated radio from the factory you can get a factory non integrated dash bezel for it and put the pioneer in i have one in my yaris
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 11-16-2008, 03:46 AM   #3
mhkritzinger
thanx alot for your reply!! will you so kind and post a few pics?? and i want a nice clean finish with no gabs and so will the pioneer system cover the space nicely?
Thanx
Old 11-16-2008, 12:32 PM   #4
sportin83
Drives: 2008 blazing blue yaris LB
i got a pioneer avic-z2 which is a double din. very similar to the 4000 but mine has nav and a motorized face. there are pics in my cardomain link in my sig
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 11-16-2008, 12:34 PM   #5
sportin83
here is a pic after install in a 2008 lb
Old 11-18-2008, 11:16 PM   #6
jdms
jdms's Avatar
Drives: 08 Polar white lb
what are the piece's on the saide that fill up the gap of the double din and where do you get them?
Clean install btw
jdms is offline   Reply With Quote
Old 11-25-2008, 03:07 AM   #7
battleversiontc
you can get them at crutchfield.com they are called double din fit kits but they sell them at crutchfield
Old 11-26-2008, 12:16 AM   #8
sportin83
i bought mine at circuit city. it is made by metra. the double din dash kit.
Old 11-29-2008, 07:34 AM   #9
battleversiontc
yeah or bestbuy have em too
Old 11-29-2008, 10:43 PM   #10
jdms
jdms's Avatar
hey thanks alot! For those that have Navi installed.
I'm getting my Avic d3 in this week and was looking over the installation manual and the only questions i have are:
1. What wire did you spice into for the vehicle speed sensor wire?
2. did you actually hook up the reverse wire?
3. i was reading someones install and to do the bypass (get dvds and change destination while moving) you have to ground out the e break wire. is this true.
Any help will be greatly appreciated. Someone should do a write up for DIY for navi systems
Old 11-30-2008, 06:40 PM   #11
sportin83
you do not need the speed sense wire. the unit will do hybrid learning and will calibrate itself using the gps. the reverse wire is not needed unless you add a backup camera. and for the bypass most pioneers need software updates to override do to the built in gyro sensor. on my avic-z2 its shuts off controls at 10 or 15 mph. but all you have to do is take green wire which is ebrake wire on pioneer unit run that to a basic toggle switch and then take the other side of toggle to ground anywhere in car and then you flip switch unit thinks break is on. hope this helps
Old 11-29-2008, 10:56 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
For those who want the double din dash kit, go to Metra's website (www.metraonline.com) and use their vehicle drop-down menus to find their dash kits for the Yaris.
Old 11-30-2008, 11:46 PM   #13
jdms
jdms's Avatar
thank you so much! all questions answered
Old 12-02-2008, 06:03 AM   #14
battleversiontc
if you do that way it will lock you out the correct way to do it since i own a d3 was to pull the mute wire outta the harness along with the metal tab and move it to the pin above and ground that wire and the parking brake wire. you cant use the old toggle switch trick cause as soon as it senses movement it will lock the menu out or shut the screen down theres an actually thing on avic411.com to do the bypass for all the avics they come out with
