Old 11-17-2008, 08:41 PM   #1
auxmike
auxmike's Avatar
Best tool I've found so far to remove oil filter PICS
The black steel cap one from PepBoys is awful and hops a lot. The Channel Locks work, but there's not really enough room in that area so you have to tilt the pliers down and that makes it real hard to get a good solid grip. The AST is an all aluminum casting and fits like a glove!
Old 11-17-2008, 09:04 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I've got something very similar. It's plastic and fits a standard socket wrench. Works like a charm.
Old 11-18-2008, 04:13 PM   #3
stran
Drives: '07 Yaris 3D HB Auto
i use the walmart oil filter wrench and that works fine. it's the same design except plastic and costs $2.
stran is offline   Reply With Quote
Old 11-19-2008, 03:19 PM   #4
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I used one of these last time. I guess the torque spec on the filter is like screw on till it hits the top and then a 3/4 turn. The specs are in the service manual Thomas provided on here.
Old 11-22-2008, 07:00 AM   #5
nemelek
DWEED
nemelek's Avatar
The factory oil filter had more torque than 3/4 turn. I have found that 3/4 to 1 turn works well and I am able to remove the old filter by hand.
Old 11-19-2008, 03:25 PM   #6
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
nice to see it fits the newer cartridge ones as well.....
Old 11-19-2008, 06:24 PM   #7
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
I use K&N filters it has a "nut" built in so it can be directly removed with a wrench.
bdc87 is offline   Reply With Quote
Old 11-19-2008, 07:12 PM   #8
ToddR
Bacon!
ToddR's Avatar
Drives: 2008 Red Yaris LB
+1
ToddR is offline   Reply With Quote
Old 11-21-2008, 12:27 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
I have plastic unit for a couple bucks for doing my sister's car, How much is this piece? Would be C-O-L-D in winter!
Old 11-21-2008, 06:16 PM   #10
auxmike
auxmike's Avatar
About $20USD.
Old 11-21-2008, 12:29 PM   #11
TheSilkySmooth
BTW any one find a good source for drain plug washers like under 25c each? No way I'm paying dealer a 1 euro for a penny washer. Can you use brass from the hardware store? and are they 12 or 14 mm? Sorry for all the questions.
Old 11-21-2008, 06:19 PM   #12
auxmike
auxmike's Avatar
I splurged and bought 10 washers for $10 from the dealer.
Penny wise and Pound foolish can cost you a lot in the end.....
Old 11-27-2008, 11:53 AM   #13
TheSilkySmooth
Thats not pencewise - thats a ripoff. Its a goat-mule sacrifical drain plug washer not even remotely high tech. Boy, you americas throw your money away like its been given too you by rich daddy! Drive up coffe for three euro a cup and complain about gas cost. Very Hilarious! I'll save the buck and buy the next better grade OIL FILTER or Euro Oil where it may do something good for the motor. If you dig through garbage for food and cloth 1/2 your life you will not be so cavalier about throwing money away. So Brass washer, hot plunged in zinc or stannum will do great for "crush washer" So is it 14mm or 12 mm DIA?
Old 11-27-2008, 12:25 PM   #14
auxmike
auxmike's Avatar
To each his own.
Old 11-28-2008, 09:16 AM   #15
TheSilkySmooth
To each his own.
Yeah, I like the toyota washer, Good for 3 uses at least, but a buck? I am still on the original after 4 OC and time for new, We used spark plug washers in europe but no parts guy seems to carry anymore. Maybe with advent of $$$ iridium-tip sprak plug the replacement washer will come back. On the spark plug you shouls ALWAYS putting on the new crush-washer if you pull a plug. I see many Subaru's with toasted heads from backed out plugs and reused washers.
back into the oil pan = Guys, just do not substitute with a zinc-dipped steel in the vintertyme - it will dissapear (rusting) if you getting the salz-wasser on it!
Sonja's bro
Old 11-22-2008, 04:45 PM   #16
earljail
earljail's Avatar
Drives: 07 Yaris Hatch 5speed
Well, they are "crush" washers, so they are special. If you want to be cheap, just reuse them. I do replace it each time on my Yaris, but I didn't used to with the other cars I've had.
earljail is offline   Reply With Quote
Old 11-21-2008, 06:25 PM   #17
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
?????????? you know they sell this auto tightening chain wrench where you attach the links on the oil filter and then crank it... works on every one of our cars even when it is stuck on...
Old 11-22-2008, 08:07 AM   #18
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Interesting, never seen that before.
What about the oil filter???? Driver DIY / Maintenance / Service 28 10-23-2008 11:45 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Toyota oil filter difference in sizes? pics Ogredude DIY / Maintenance / Service 7 04-02-2007 01:16 PM
