Old 11-18-2008, 02:33 AM   #1
richardholdener
Drives: 2008 Yaris hatch
Stock vs 123 Wheel HP (All-Motor) Dyno Graph
Here is a graph of the baseline runs with the stock yaris (the one we are using to design production intake with). The after graph is a result of a few mods including the new long-tube header, Dynatek intake, Xd TB and NST under drive pulleys. It looks like exceeding 120 wheel hp will definitely be possible with bolt on mods assuming they inlcude the long-tube header 9and mid pipe) and new intake manifold. This test was run with a version that is identical to the production piece so these gains will be possible. Possibly more power with light-weight oil, tuning from FIC (needs more ignition timing) and real CAI (we ran the stock filter lid turned upside down)-I forgot my TRD/AEM CAI back in Vegas for this test (in Palmdale). We might be able to get to 130 wheel hp in real street trim! BTW-Check out post on intake update.
richardholdener is offline   Reply With Quote
Old 11-18-2008, 02:34 AM   #2
pinoypizzaboy
Drives: 08 toyota yaris LB
where can i get richard holdner built stickers for my car?
pinoypizzaboy is offline   Reply With Quote
Old 11-18-2008, 02:42 AM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
whats different about the xd TB than the yaris?
Old 11-18-2008, 02:47 AM   #4
richardholdener
The Xd throttle body is larger than the Yaris but it plugs right in and runs perfectrly on the yaris. Just needs a minute or two to idel down the first time you start it-ECU is not use to having such large throttl eopenings at idle but once this self adjustment takes place right after initial start up-it works perfectly and was worth roughly 2 hp at this power level. Intake will come with flange to accept Xd TB and have adapter plate to neck down for yaris TB.
Old 11-20-2008, 04:35 PM   #5
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Any chance u have any pics of the TB installed on the yaris?
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 11-21-2008, 01:08 AM   #6
richardholdener
The Xd TB was installed on the prototype intake-we won't have photos of the new intake until the production piece is ready. Externally, the Xd TB looks the same as the yaris.
Old 11-18-2008, 02:48 AM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
awesome! your the man richard!
Old 11-18-2008, 02:57 AM   #8
ChinoCharles
Drives: LB
Richard, how are these N/A geared mods going to work with a forced induction setup? Will they still add power? I understand that they aren't designed for use with a turbocharger, but I am hoping that they will still add to the whole picture and not take away.
Old 11-18-2008, 03:00 AM   #9
richardholdener
For a turbo application, the intake and NST pulleys will work well. Can't really do a long-tube header for turbo application-but it would definitely help if it could be fit-anything that helps NA power will help in forced induction. A rotrex blower set up could use all of the listed mods. Blitz blower could use long-tube header and pulleys (all could use a good CAI).
Old 11-18-2008, 03:25 AM   #10
pinoypizzaboy
im a noob but 20+ whp is a big change for the yaris ecu wont this require some management of some sort? this is almost the same gains as the blitz
Old 11-18-2008, 12:11 PM   #11
richardholdener
Since this is a mass air management system, it has been very self compensating in terms of air/fuel and timing (we monitored via palm pilot), so no changes to ECU are necessary. Air fuel curve was basically same as stock. We think additional timing may help power since we were only registering a peak of 20-21 degrees (less in the mid range).
Old 12-13-2008, 04:24 PM   #12
4MPG
Drives: black 5spd hatch yaris
Pretty impressive.. dammed near 25 percent increase in power with zero tuning and only boltons.
Is there no way to tune the car other than a complete standalone system? I can defiantly see where your loosing some power to the tune (especially the dips between 4200~ and 5500~).
I have seen (on this forum) where people did piston swaps from other Toyota cars to get a bump in compression, any plans to try this out on your test mule?
4MPG is offline   Reply With Quote
Old 12-13-2008, 05:49 PM   #13
richardholdener
I am very curious to know how you see where we are losing power due to tuning based on the graph provided. Since there is no evidence of the air/fuel ratio or timing values, how do you know where tuning may improve the power? To answer your question about tuning, we will be employing an FIC on the yaris motor (basically to increase the timing-since air/fuel is near spot on already. No plans on changing compression-the test motor belongs to another forum member and we don't think he will like us tearing his motor apart. BTW-The dips in the curves you are refering to are a function of the resonance waves from the long-tube headers and intake manifold.
Old 12-13-2008, 06:07 PM   #14
4MPG
Your seeing these kinds of dips etc due to the headers? The dyno sheets of the before/after of the headers really show some spots (4-5200) where it looked like a tuning issue, as it was present but not as exaggerated on the stock dyno, which I figured was a tuning issue. Its probably alot less important than it looks... on this scale every small change looks like a monster.
Old 11-18-2008, 03:29 AM   #15
jkuchta
Drives: 2007 Yaris hatch (red)
So tell me about this long tube header. When will it be available, and will it mount to the stock midpipe?
EDIT: I just saw the other thread!
jkuchta is offline   Reply With Quote
Old 11-18-2008, 08:24 AM   #16
niiiiiiice, now that is a meaty increase across the range
Old 11-18-2008, 10:47 AM   #17
Dylan Yap
Drives: Toyota Vios
do you have a AF chart too? dynojet can print AF too
Dylan Yap is offline   Reply With Quote
Old 11-18-2008, 11:01 AM   #18
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Yaris Long Tube Header
Hey, for anyone wondering how the Yaris long tube header looks....
Here you go! Richard just sent me the picture...
Stock Wheel Covers barryware Willing to Buy by private party 5 11-04-2008 01:22 PM
Stock Wheel Covers? barryware Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 11-04-2008 10:03 AM
stock wheel wushumasterku Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 08-23-2007 11:52 PM
