Old 11-20-2008, 12:57 PM   #1
Weight Savers
This could go under fuel economy too, but for me it's a performance issue.
Please post up anything you've taken out of the car and WEIGHED. I'd like to start a list (like we used to have) of what the savings are on each item.
I can start with rear 60/40 seats, which I removed this morning.
40% seat = 35.5 pounds
60% seat = 55 pounds
TOTAL = 90.5 pounds
3 rear seat belts are next.
Old 11-20-2008, 01:14 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Clean out 3 months of trash
5lbs
Old 11-20-2008, 01:21 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I think it would be appreciated by all if the comedy were left out of this thread.
The one-piece rear seat weighed as follows:
Rear Bottom - 11.0
Rear Bottom Support - 6.0
Parcel Shelf - 1.5
Rear Back - 36.5
Belts (all) - 7.5
Total - 62.5
Stock steel wheels weigh around 19 pounds each. Replacing them with readily available 12 pound alloys saves a total of 28 pounds (and it's rotating mass, which really helps acceleration and braking... and unsprung weight, which helps ride quality and handling over rough surfaces).
Old 11-20-2008, 01:25 PM   #4
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
I have removed the rear trunk area, plastic compartments and spare tire but I do not have a scale available. Could someone please find the weight of these components? Thank you
Wanted: Forced Induction
Old 11-20-2008, 01:33 PM   #5
5lbs
Rear Bottom - 11.0
Parcel Shelf - 1.5
Rear Back - 36.5
Belts (all) - 7.5
Total - 62.5
If by chance you were referring to Yoda's post, it is a valid post with a good percentage to gain in fuel economy.
Old 11-20-2008, 03:59 PM   #6
m911gt
Carless in Chicago
m911gt's Avatar
Drives: 08 Blk LB
True, however if one's car is filled with garbage, they are most likely not as concerned about negative effects of weight addition as the rest of us.
Old 11-20-2008, 04:33 PM   #7
Yoda
Yoda's Avatar
But i cleaned it lol so i must care about the weight. Are you guys telling me if you look right now in your car there is no trash in there...And the trash i am talking about are a bunch of school papers and tools.
Old 11-20-2008, 01:35 PM   #8
lower center trim piece (where the shifter and e-brake are) = 1.5 pounds
front door panels = 8 pounds each (7lbs, 14oz.)
Old 11-20-2008, 02:05 PM   #9
jkuchta
Drives: 2007 Yaris hatch (red)
the headliner felt like it weighed 3-5 lbs.
The carpet felt like it weighed 15 lbs, (no scale).
Does anyone know where I can get the entire car weighed here in Socal?
jkuchta is offline   Reply With Quote
Old 11-20-2008, 02:07 PM   #10
good question. some recycling places might let you drive onto the scale, or let me ask Rick over at the shop. I'd like to weigh mine too.
Old 11-20-2008, 02:15 PM   #11
headliner: 5 pounds
Old 11-20-2008, 02:40 PM   #12
jkuchta
cool...that weight is really high up too!
Old 11-20-2008, 02:49 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
full interior out:
front seats: 65lbs each (130 total) + 44lbs seats/brackets back in
steering wheel: - 8 lbs + 2lbs
seatbelts... 5lbs savings removing all belts, + sparco in
rear seats out 90lbs + harness bar 25lbs
passenger airbag.. 9 lbs
carpet and padding: 17 lbs
rear wiper and rear plastic panels 15lbs
spare tire and rear deck lid 30lbs
stock wheels - 15X7's with 225's.. i call it a wash
headliner+ a and c pillar plastic 7 lbs
around 240lbs savings..
last time i weighed the car it was 2133lbs on 17X7's (about 30lbs total heavier than my 15's, plus passenger airbag and carpet)
estimate car to be at 2133 still.. stupid turbo is heavy
Old 11-20-2008, 02:57 PM   #14
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
contact any race shop to get your car weighed... they shouldnt charge you much, but they would also be able to tell you corner weights just make sure your tires are properly inflated before you go on the scales
turboyaris is offline   Reply With Quote
Old 11-20-2008, 03:00 PM   #15
YAR1S
YAR1S's Avatar
shoot, go to a junk yard. If you ask them they might let you drive your car onto their truck scale. You could always slip them some money, lol.
Old 11-20-2008, 03:20 PM   #16
A pillars: 1.5 pounds (for both)
Old 11-20-2008, 03:38 PM   #17
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Brake pedal assembly: 9 lbs. Clutch assembly: 7 lbs. Plastic gas pedal assembly: 2 lbs. I suggest keeping the gas pedal, otherwise you can't even go...
Sorry, couldn't resist.
Old 11-20-2008, 04:08 PM   #18
NonStopTuning
Excellent thread Garm!!!
Weight Savings 03Z33 Performance Modifications 30 01-31-2009 04:14 PM
6lb 6oz ultra light weight battery heavystarch Performance Modifications 28 11-19-2008 06:02 PM
Yaris Curb Weight, difference LB vs Sedan CASTREX General Yaris / Vitz Discussion 14 12-12-2006 09:50 AM
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
