The Martian
Six speed
GrassrootsMS had posted the top speed for our transmissions in the top speed thread (146) and i was wondering if anybody had retrofitted, or heard of someone who has, a six speed transmission like the celica gt-s?
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
for the right price... i could make it happen
![]() the first major hurdle i would say is going to be your axles, I'm not too sure, but you would more then likely need custom axles which are quite expensive. |
#3 | |
The Martian
But seriously I might...
Not really here...
Drives: 2008 Blazing Blue S hatchback Join Date: Oct 2008
Expensive to some might be very reasonable to others.
Liberate Tutemet Ex Infernis. |
The Martian
EXACTLY!!!
the good new is, the clutch could remain the same, both use a 21T spline that is 24.1 mm in diameter
haha well... do u have access to a 2zz trans? basically, I did some quick searching, and I couldnt find if the bolt patterns were the same or not, I know that the 2zz and 1zz have the same bolt patterns, and I know that the 1nz and 1zz are very similar in size and components, so it wouldn't suprise me if they just bolted up. the only other situations to be looked at are 1) that the clutch (which fits on the 2zz main shaft) properly engages the main shaft i.e. the splines have enough depth into the clutch assembly 2) the trans is slightly larger i believe, so modifications to the engine bay may be neccessary 3) the main snag i believe may be the axles, since the input side of the 2zz axles would most likely be larger and possibly different splined then the yaris, plus the axles may need to be longer or shorter. If i remember though, I was going to get some custom axles done, and if you supplied them with 1nz and 2zz axles I think they could be made for.... ~$400, not sure though..... and lastly the shift linkages, which should be the easiest task to overcome, but don't quote me on that... basically anything is possible, and if 1 and 2 work out with no modifications, you would be looking at an inexpensive swap.... oh and trans mount, which shouldnt be difficult either... I'd have to see the two side by side, or get some measurements. but its definately do able.
does the 2zz come with an LSD cuz thatd be a cool plus and i also forgot to mention, the slave cylinder setup would have to be on, but if its not... thats easily adjusted |
The Martian
Are you planning anything next summer cuz if not in all seriousness I might be making a trip to Jersey!! I asked my friend who has a Gt-S and he said his didnt come with a Lsd....I wonder why this hasnt been done yet
i had forgot that I was doing custom axles for my own car... I was thinking like driveshaft shops outrageous cost of 1300$
cuz im crazy like a fox........ and not everyone else is
Who said Yaris was slow?
hint
2009 Yaris TS comes with a 6speed from factory.
The Martian
Sounds like a simple solution...but the top speed on the yaris one is probably the same as the five speed...
my guess is itll probably be a c60 maybeeeee i c64, but unlikely which would be a whole lot cheaper bought used out of a celica, then new from a toyota dealer, plus it could technically have the same problem since the engine is dif anyways
#14 |
I used to have 1700 posts
drive shaft shop axels for yaris in this thread
http://www.yarisworld.com/forums/showthread.php?t=9884 |
#15 |
well the driveshaft shops are actually the same spline/ diameter, I was told that the easiest way to beef up the axle, is to actually go with a larger outboard side, as thats where they usually snap. I was originally going to get axles made with the yaris inboard side, and do a 5 lug tc swap, and have a tc wheelside axle if that makes sense. I'm not even sure the driveshaft shop makes custom drive axles. they may only sell the ones they have. The reason for the cost being so high, is they used a stronger metal, and all that machining to make those parts is very expensive. It all would come down to where the transmission housing would sit, and if the axle lengths would need to be changed.
#16 |
The Martian
Yeah that makes sense im going to look around and try to figure out the specifics of this project
#17 |
lemme know if you need any help
| Max Speed in Each Gear for 5 speed man. Yaris with no tach?? | 09TRD | General Yaris / Vitz Discussion | 53 | 09-24-2010 04:18 AM |
| TWM 5 speed engraved shift knobs | TWM Performance | TWM Performance | 19 | 02-10-2009 10:42 AM |
| Finding a 5 speed LB to test drive | grampi | General Yaris / Vitz Discussion | 16 | 05-10-2007 07:58 AM |
| Speed Control | Bms2236 | General Yaris / Vitz Discussion | 8 | 02-26-2007 03:50 PM |
