![]() Drives: 3 dr 1.3 2NZ Join Date: Dec 2008
90% on short trip. What to do to protect engine?
Hi guys, need some help on how to prolong the engine lifespan of my 1.3 auto Yaris. My trip is 90% made up of short trip (less than 7km) and I know that this is quite detrimental to the engine. What can I do to minimise the engine damage beside regular oil change? If I make a long trip every week (purpose being to vaporise the fuel and moisture that acculmulate in the engine during short trip), would this help in protecting the engine? Thanks in advance for the expert advices!
The Martian
Its a small thing but run synthetic oil and try using a magnetic drain plug^_^
"The lead car is absolutely unique, except for the one behind it which is identical." F1 commentator Murray Walker. |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
Since the engine really never warms up, just drive it gently. No jack rabbit starts when leaving lights and give the engine 15 seconds or so on initial start-up before putting it in gear. I'd change the oil every 3-4 months under these conditions. Driving at higher speeds to burn off excessive fuel/water that gets into the oil from running cold all the time would only prolong the life of your oil-not your engine. Keep fresh oil in it and you'll get all the life you'll want out of it.
drive it hard on the freeway at high revs freely like you are doing once a week and you will be okay. And just change your oil every 3 months instead of 3k miles.
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
The Martian
What are you saying? Do you not think the Yaris is worth keeping?
#7 | |
Are there some other members who share my views? |
#8 | |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
Making a decision without following it with an action is still a fantasy. |
#9 | ||
i had just assumed you meant that after 5 years (and this is a typical thought of we, the ones with snow and ice) the body will rust out before the engine goes bad. which, is exactly opposite way things happen in warmer climates i have friends (husband/wife) in town with a 2002 hyundai accent 5spd. its done 150,000kms in its time, but theyve never had anything significant go wrong. i say its theyre driving. they NEVER shift above 3000rpm (which is often scary as fvck when they pull out in front of people) and as far as i know, never run it up. a lot of the miles were put on from moving between the maritimes and ontario and between halifax and fredericton, but otherwise, they just do short-ish, in-town driving (fredericton is only 50,000 people) id say if you take it easy on the car and do the regular maintenance, the normal wear parts will last a LOT longer than driving the car hard. but id take it on the highway once a week and get the carbon out of the exhaust! ;)
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
Walk.
i have just a comment about the engine reving...
does your piston go further when you rev higher? :P |
The Martian
In theory its moving faster so it may ,by a very small margin ,flex a little farther^-^
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
90% short trips mean your oil is probably experiencing fuel dilution. In addition, your oil probably does not warm up enough to boil off the fuel, and in addition, the oils is not hot enough to give the best protection; in other words, the oil may not be reaching the optimal operational temperature to maximize circulation up and around all the engine parts. This is where a lighter weight oil provides more protection over a heavier oil. And it is well known that 90% of the wear and tear inside an engine happens during the first 5 minutes of operation, and it is during this time you most want the oil to protect. It full operational temperatures (usually around 200F to 212F) there is little added protection when synthetic is used over mineral oil.
So to mitigate this I would strongly suggest running 5W-20 weight oil, as it will circulate all over the engine internals faster then 30w during the first 5-10 minutes after first start of the day, and better faster circulation during the first start of the day means less wear on the internal parts. I would use synthetic too, as it often contains better additives that will help deal with oil that is fuel diluted. One last thought: Never equate oil temperature with water temperature. There is no linear correlation, so even if your water is 181F, your oil is not necessarily up to it's expected operational temperature, and often oil takes 20-30 minutes to reach 212F or thereabouts. And it is only after it reaches those temps, will the fuel in the oil boil/burn away. You might want to get your Yaris on the freeway for 30 minutes at least once a week to minimize the fuel dilution issues. So in summary: Use the cheapest synthetic on sale that is 5w-20 or 0w-20. Another benefit of doing this is that you should be able to run your oil 25% to 50% longer over mineral before you have to change the oil. Until the car is fully warmed up, don't jump on the gas pedel....keep it slow and smooth. You do this, and your engine wil easily reach 300,000 miles without buring oil, or losing much power. |
#14 | |
Lil Monsta
Drives: Super White Yaris 08 Sedan Join Date: Dec 2008
well since it's winter, i think it won't make a different with a 5-20 or 5-30 right now because the 5 is the winter weight correct? |
#15 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Correct. And I don't know why he suggested 0w-20 in his reply...that's very bad advice. The Toyota TSB that he's referred to many times clearly states that 0w-20 is not recommended for the Yaris 1NZ-FE motor.
#16 | |
The TSB IN FACT says we can use 20 weight oil in our Yarii, 2007 and going forward. The special note at the top are for vehicles NOT COVERED by that TSB, and for those, one should look at their owner's manual, and/or what is printed on the filler cap for the proper oil weight. |
#17 |
That lower number (0w-20 or 5w-20) is only relevant on startup,once the engine warms up the higher number is the relevant oil viscosity
#18 | |
![]() And I never found the part about vehicles "NOT COVERED" ...I think it states "each vehicle" after stating: ILSAC GF4 can be used in all Toyota and Scion engines. It's dealing with all Toyota and Scions, not Hondas and Hyundais |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| Yaris and Echo short shifters sale, $30 off! | TWM Performance | TWM Performance | 8 | 11-17-2008 02:23 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
