Drives: 2007 Yaris Sedan S Join Date: Dec 2008
2007 Yaris Sedan S Ignition won't turn
Help! I've called the Toyota dealer and I've tried what they've suggested to do. First, it's very cold where I am at. I went to try and start my car and the key won't even turn in the ignition. I tried moving the steering wheel to the left and right back and forth while trying to turn the key and nothing. I used a blowdryer thinking that maybe it was frozen - no such luck, tried WD40, nothing, the key wouldn't budge. I made sure that the transmission was indeed in park and still nothing. Now I'm stuck with no way, other then towing my car to the dealer which is about 40 miles away. I've never experienced this before. It's acting like how it works when your outside door lock to the car door is frozen.
#2 | |
Mine does that sometimes but it is just where the steering wheel is locked. Just try turning the wheel as much as you can to the left or back and forth while trying to turn the key but dont force turning the key.
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
If you look in your owners manual it will tell you what to do in this situation. If you look down on the middle console where your gear shifter is, you should see a little square shaped piece that is right above the shifter. If you pop that little cover off and stick your key in there, it should fix your problem.
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
...unless the steering column is jammed. I helped a lady in a parking lot recently because she bumped the curb, slammed it into gear and turned the key to lock position, all in one fluid motion. I had to turn the steering wheel with a lot of force, while turning key with normal amount of force. When I finally put enough pressure on the steering wheel the key turned with no effort...but I nearly dislocated my left shoulder when the steering wheel broke free from being in a bind.
#6 | |
2007 Silver Streak Mica Yaris S Sedan 5 Speed dojo TSUKAMI Shift Nob Brake Light Pulser Daytime Running Lights http://www.webelectricproducts.com/products.htm |
#7 | |
Lucky your in warrenty. Ignition locks are a pain in the ass if you can not turn the key. Usually requires removal of the entire steering colum and possible help from a drill to remove it.
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
