Old 12-27-2008, 08:41 PM   #1
letstry1234
Drives: 2008 Yaris liftback Red
I get a rymthic hum at about 72-75 MPH?
I have noticed this after the break in period. (kept it slow for break in) I get a very rymthic hum at a little over 70 MPH. every 2 seconds or so..on then off. sounds like it is coming from the front somewhere. hasn't really bothered me a ton i have rebalanced the tires & rotated & also replaced the wheels, (not for this but to get away from the hubcaps). i can only hear it when the radio is off. very light sound. just wondering if anyone has the same sound. I now have 13,000 miles & it has never been to the dealer. i have done all my own maintance.,, 1,000 mi oil...3,000oil...5,000 syn oil... 10,000 syn oil. checked trans fluid properly.
letstry1234 is offline   Reply With Quote
Old 12-27-2008, 09:20 PM   #2
xpeteyjtx
Drives: 07 BB Yaris
You will hear many noises coming from somewhere in the Yaris. I get a whine/hum at about 40mph.
Sleep well at night, as you have a 3 year/36 month warranty. If it gets worse, take it to the dealer. The noise is probably normal.
The hum/whine still remains a mystery though. I wish I knew what it is.
VVT? solenoid?
rotational frequency of transaxle? or engine (not likely)?
xpeteyjtx is offline   Reply With Quote
Old 12-27-2008, 09:33 PM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
same here, i get a funny hum when going 60-70 and i let go of my gas pedal....i believe our transmissions function like that.....it's weird........
Yawesh is offline   Reply With Quote
Old 12-27-2008, 11:50 PM   #4
letstry1234
yeah it isn't that loud, I kinda figured it was fairly normal. and actually I have the 100K Toyota extended warranty, so I was not too worried. just wondering if people had similar noises. love the forum. it helped me do the TRD lowering springs in about 2 hours, I need to get a picture up
Old 12-28-2008, 12:09 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
actually.. mine became more noticeable ever since i got a control arm/table changed. And mine has a part that is out of spec, and that cannot be adjusted in the alignment.
Old 12-28-2008, 01:32 PM   #6
manual or automatic?
Old 12-28-2008, 02:05 PM   #7
YAR1S
YAR1S's Avatar
Mine hums at 35-40 mph...
I know its probably the tires though.
Old 12-28-2008, 02:18 PM   #8
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Get that too past 60 MPH. Always thought it just road noise
Old 12-28-2008, 09:56 PM   #9
Cutie Pie #2
Drives: 2014 Honda CR-V LX
I get it too 60-65 and up. I had a car a few years ago it came with cheap tires which had the same kind of hum, I changed them to a better tire and the hum went away. I want to change the tires soon on my car anyway they are already wearing, maybe it will help?
Cutie Pie #2 is offline   Reply With Quote
Old 12-28-2008, 11:06 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Its our tires. If you have the factory bridgestones the only way to get rid of that road noise is to replace the tires. But dont worry they have a treadwear of a mear 160. So that will happen very soon. Even with proper rotation the max life you will get is maybe 2 years.
Old 12-30-2008, 07:12 PM   #11
Got it too, and with 3 different sets of rubber, so no it is not the tires.
Old 12-29-2008, 11:43 AM   #12
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
mine has a pulsating light hum at 55-65 and when i let off the gas it stops.. did it the day i bought it and has done it ever since.. everything works fine and havent had any issues.. if there is an issue.. the dealer will hear about it
Old 12-29-2008, 04:58 PM   #13
Dbeau
Dbeau's Avatar
Drives: 2007 Yaris Sedan Aero
I get that noise also. Thought it was my aftermarket 17" tires, but the 14" snows do it also. So I assume it isn't tire related.
Dbeau is offline   Reply With Quote
Old 12-30-2008, 08:55 AM   #14
500snakz
500snakz's Avatar
Drives: 08 Polar white hatch
The yaris has no sound deadning. The pronounced road noise and that hun at aroung 65-75 is allways going to be there unless you put in a lot of dynomax.
500snakz is offline   Reply With Quote
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 12:14 AM
17" rims and fuel economy songa Fuel Economy Forum 27 12-20-2008 11:44 PM
MUST READ!!! MPH to RPM to Time ratios,gas savings! eco Off-topic / Other Cars / Everything else Discussions 13 09-30-2007 02:00 PM
